Next stage of the build
Old Mar 1, 2009 | 07:48 PM
  #251
leftcoast32's Avatar
FormerVendor
Originally Posted by leftcoast32
Here are a few updated pictures of the progress. I will be running everything over for Powder Coat tomorrow and then will do the final installation. I still need to make the Switch Plate and run the rest of the lines. I also need to do all the wiring and install the NOS 3.5 LCD Launcher System.
Nitrous/Nano Rack
Solenoid Mounting/Relay/Purg Brackets
Originally Posted by OnyxSilveradoSS
are you running the purg thru the floor? my buddy had to pull his bottle out b/c the purge was not up to spec.
The Solenoids are all in the front behind the bumper and headlight. The Purg blows out the brake cooling duct on the passenger side. The Blowoff Valve and Nitrous Lines go through the floor with Bulkhead Fittings.
I will post more pictures this week when everything is back from powdercoat and mounted.
Old Mar 5, 2009 | 07:42 PM
  #252
FormerVendor
We got the Nano/Nitrous Rack back from powdercoat and finished the installation.
We had the bottoms of the bottles done in Line-X to prevent chipping.
We sanded and then covered the aluminum panels in clear acrylic enamel.
The lines (-6 Nitrous and -8 Blow Off) have bulkhead fittings in the floor of the compartment. This is so we can pull the lines and cap the bulkhead fittings when not in use. Once the lines are pulled the compartment cover can be reinstalled.
Old Mar 5, 2009 | 09:03 PM
  #253
Mr. Sandog's Avatar
Very, very nice work.
Old Mar 5, 2009 | 09:42 PM
  #254
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
looks great! anything going on the other side?
Old Mar 5, 2009 | 09:49 PM
  #255
FormerVendor
It is all set up to do the wicked twin to the set on the right.
Old Mar 6, 2009 | 08:13 PM
  #256
FormerVendor
Here are some pictures of the Nitrous Solenoid/Relay Brackets. Everything mounts up behind the headlights for easy service. The Switch Panel will be mounted inside the center consol out of site. We need to finish up the lines, wiring and NOS Launcher with 3.5 LCD Touch Screen then off for some testing. The Purg blows out the brake cooling duct on the passenger side of the front bumper.
Before Powdercoat:
After Powdercoat:
Nitrous/Fuel Solenoid Bracket
Purg/Relay Bracket
Old Mar 10, 2009 | 08:38 PM
  #257
FormerVendor
I still have alot of wiring to do but here are some progress pictures.
Nitrous Hi Flow Filter and 1/8 NPT Port for Nitrous Pressure Sending Unit
Relay Bracket with Purg Finished (Sprays out the Brake Duct on Passenger Side)
Nitrous and Fuel Solenoids (Lines Finished)
Nitrous Spray Bar Inlet with Lines Attached
Stand Alone Fuel System with Pressure Regulator and Fuel Pressure Gauge (1/8 NPT Port for Fuel Pressure Sending Unit)
Old Mar 10, 2009 | 09:24 PM
  #258
SuperchargedSS's Avatar
i seriously wish I had your talent
Old Mar 10, 2009 | 09:31 PM
  #259
FormerVendor
Thanks for the Huge Compliment!!
Old Mar 10, 2009 | 09:52 PM
  #260
supersub's Avatar
Wicked set-up Joe! That extra fuel cell is still my Fav!
