Next stage of the build
Old Sep 12, 2007 | 02:01 PM
leftcoast32's Avatar
FormerVendor
Originally Posted by Tootall
where are the rockers hitting the heads? . . . on the push rod side?
The L92's have an increased thickness to the Valve Cover Rails on the intake side like the aftermarket LS1 heads. They are hitting right on the end for the pushrods. I sent them a head and the rockers this morning and they should have the issue resolved so they can go into production of these. The rockers are 10 grams lighter then the stock rockers too.
The only down side is that if we have to use 1.8 ratio for clearance I will need to have another cam ground as I have the cam here already and it was ground for the 1.7 ratio.
Old Sep 22, 2007 | 10:24 AM
FormerVendor
Plans changed a little on the rockers. They will need to redesign the push rod cups in order to use the rockers on the L92 heads.
I have a set of the stock rockers ordered from Scoggin and Dickey along with the rocker supports and bolts. I am sending the stock rockers to Harland Sharp for the HS Modification. They change out the fulcrum so the needle bearing don't fall apart. I will post up pictures as soon as I get them back.
Old Sep 23, 2007 | 12:22 AM
rpav's Avatar
i am going to send mine in as well. just waiting for the new set to come in. do you know what they charge for this?
Old Sep 23, 2007 | 09:47 AM
FormerVendor
I have not been billed yet because of the change in plans. I have seen it on LS1Tech that they charge $250.00 to do it for you.
Old Sep 23, 2007 | 01:13 PM
rpav's Avatar
cool, thats what Richard thought when i asked him.
thanks
Old Sep 23, 2007 | 08:38 PM
FormerVendor
thanks
Did you get a set of his L92's also?
Old Sep 24, 2007 | 11:41 AM
rpav's Avatar
i bought a set of the stage 2 317's from another member here and had them sent to Richard to go through. If not for the great deal i was considering the L92's. Once the new rockers come in from the dealer i'm going to send them out to Harland for the conversion. I also have a 122 waiting to go on and a comp cam with Richards suggested specs for my truck. My blower is satin but i'd like to have it polished. I think i read that you were the man or you had the hookup. I also need to get on a set of LT's.
Old Sep 24, 2007 | 11:58 AM
FormerVendor
Give Robert a call at Sanchez Plating and Polishing (760) 743-4988, they are located in Escondido.
Old Sep 28, 2007 | 07:26 PM
FormerVendor
I received the modified L92 Rockers back from Harland Sharp today. They remove the needle bearing and replace the pivot with a new one that has c-clips. These use the stock L92 Rock Supports and they come with new rocker bolts.
The L92 Roller Tip Rockers will come out some time in the near future, I will try a set when they are available.
Stock L92 Rockers
Harland Sharp Modified L92 Rockers
L92 Heads with Harland Sharp Modified L92 Rockers Installed
Old Sep 28, 2007 | 07:57 PM
Slowhawk's Avatar
LS1Tech Sponsor
Since your in the testing stage have you thought of testing back/back the L92's against another head like AFR,ETP,or trickflow?
