Next stage of the build
#186
Yes, I made it from the stock 3/8" hard line.
I plan to upgrade later to one of the designs I have been thinking about below:
Return System - Use a boost referenced regulator (return system) so I can adjust the pressure to compensate for the boost pressure at the head of the injectors. Designing a system so that I can make a custom y-block with -8 inlet and -6 return feeding dual -6 to the fuel rails. It will be an easy conversion from where it is now.
Returnless - Integrate a second fuel bucket that will kick on at a certain boost level with a switch. This would retain the returnless and use 2 pumps to feed the rails. The y-block would then become an x-block so the 2 pumps and 2 fuel rail lines would join at this point. This would almost double the volume output when both pumps are running.
#189
I need to flow a certain amount of fuel to support a certain amount of HP. I want to be able to support 1200-1500 FI HP. I don't want the restriction to be the fuel system. The stock system with MagnaVolt will support about 800 FI HP at the Crank before you start to see a pressure drop. This current change should push that out enough to crank the boost a little higher and help to support the Nitrous I will be trying.
I can not fill a 55 gallon drum with a single 3/8" line very fast but I can fill it twice as fast with (2) 3/8" lines.
I have also built several fuel systems for Street Rods with the aftermarket in-line pumps. I want the dependability and longevity that the Walbro 255HP pumps provide.
This is why I am seriously considering the system below, it will feed twice the amount of fuel to the engine and support even more power.
Returnless Dual System - Integrate a second fuel bucket that will kick on at a certain boost level with a switch. This would retain the returnless and use 2 pumps to feed the rails. The y-block would then become an x-block so the 2 pumps and 2 fuel rail lines would join at this point. This would almost double the volume output when both pumps are running.
