Need swap help(flex plate issues)
Old Jul 31, 2011 | 10:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That little bit of rust, along with being slightly mis-aligned, could have bound it up for a bit. Then "pow", it lined up & snapped into place for you.
Old Jul 31, 2011 | 10:14 PM
SlickSierra's Avatar
ill have to pull it back out after work tomorrow and see how it goes. its not bolted up with the spacer in there
Old Jul 31, 2011 | 10:55 PM
black04's Avatar
1/16" - 3/16" between the flexplate and converter mounts is acceptable. Anything over 3/16" needs to be shimmed.
Old Aug 1, 2011 | 05:50 PM
just measured each crank, they both extend 5/16" past the rear of the block and both snouts measure just under 5/8". so good to go there, i guess the converter wasnt totally aligned with the snout, bout to go back in again and double check the distance from the converter to the flex plate.
Old Aug 1, 2011 | 06:14 PM
06murder's Avatar
only need the spacer for 80e's...which if ur going to put go fast goodies i would go ahead n put one in there
Old Aug 1, 2011 | 09:56 PM
Thanks for the help guys, wound up being nothing. called the transmission shop and they said my gap was fine. everything measured out good so i guess i was worried for no reason.
XL7
May 5, 2022 01:48 PM
LCHEE
Oct 24, 2020 04:10 PM
lycominghunter
Jul 29, 2015 04:24 PM
Ketis
Jul 23, 2015 12:37 PM
mrgrim
Jul 8, 2015 08:12 AM
