My ultimate daily driver
Old 04-09-2019, 01:52 PM
  #21
Still moddin'
Reckless's Avatar
Great build. They are better when there is a good story of perseverance!
Old 04-09-2019, 09:57 PM
  #22
Shaggy2dope's Avatar
Hell YES!
A man after my own heart... a nice PD blower on a 4.8! You will love the cam as you add boost.
Lol! Cant wait. That cam plain works. I have no problem in the lovely DFW traffic. Yeah, its a little rumpity, and yeah its a little loud. I don't mind.
Cold starts sound like Slayer asked you to turn their music into a camshaft!
Vortec350ss (04-10-2019)
Old 04-09-2019, 10:05 PM
  #23
Originally Posted by thunderwagen
I had a Radix on the LQ9 in my VHO back in the day then went turbo on it and ended up with a built motor and 80e before I put that truck back to stockish and sold it. I miss having that kind of power in a daily and need a blower in my life again. I'm putting the 370 and built 80 out of the VHO in my 1990 GMC. I was going turbo on it and had just about everything to do a big T6 setup gathered up but decided to pull it all off and go back to a supercharger on that one too.
Im sure your truck just got a whole lot more fun to drive even if it is way more blower than that 4.great needs.
I dig that '90. Brings back memories. I had a '92 as my first ride. Loved it. Have a tattoo of it. I'd love to get into one of those 199x 454ss trucks. There was a dude on here who had a beautiful one!
Yeah man. I woke up smiling last night. Took a while to go back to bed!
Old 04-09-2019, 10:10 PM
  #24
Thank you for the compliment. You guys build some ridiculous stuff.
Old 04-10-2019, 01:44 PM
  #25
Still moddin'
Reckless's Avatar
Currently working on making my truck ridiculous
Old 04-12-2019, 10:26 PM
  #26
I've been bothered by the valvetrain noise in this thing since all the changes. I haven't ridden in an LS vehicle with aftermarket valvetrain, so I have no idea if what I'm hearing is normal or a problem. I measured with a length checker before going with 7.350" pushrods. I had to change plugs and decided to revisit the pushrods. I got the exact same measurement this time around.
The checker measured 7.250"-7.260" and I added .084" for preload. This put me at 7.334" total length. I rounded up to 7.350" and tossed them in. Total preload is .1"
I realize the noise could be from being too tight instead of too loose. However, I rolled many pushrods across a granite counter and they rolled nice and smooth. I'm confident I don't have any bent pushrods. I turned the engine over to the cams base circle to double check for loose rockers, none were loose. I don't know whether to make heads or tails of this.
I'm running Brian Tooley LS7 slow leakdown lifters. Comp pushrods. Brian Tooley trunion upgraded rockers. Cam Motion cam.
If anyone has any ideas, I'm all ears.
Cold
Warm
Old 04-19-2019, 10:19 PM
  #27
I've driven the truck every day this week. The valvetrain noise is still there. No better, no worse. I'm going to spin on a new filter this weekend and cut open the current one. Hopefully everything looks tight.
This thing is a lot of fun! We scored our first kill today! It was against a turbo v6 raptor. We both took off with purpose. I rolled into it 3/4 and pulled away with ease. I need to start taking my go pro with me. There's usually a good drag race onto the highway!
Old 04-20-2019, 01:10 PM
  #28
Custm2500's Rude Friend
1FastBrick's Avatar
Why so much preload?
I was under the impression on traditional LS7 lifters the goal was to shoot for .060 Preload.
What does BTR recommend for there slow leak LS7 lifters?
What valve springs are you running???
Old 04-20-2019, 01:34 PM
  #29
1FastBrick's Avatar
So it looks like BTR discontinued these due to inconsistent leak rates. The recomended preload was from .035 to .075. Try a shorter pushrod and see if the noise goes away. I would shoot for .050 to .060 range.
https://ls1tech.com/forums/generatio...l#post18213083 post 5 for discontiueing
https://ls1tech.com/forums/generatio...l#post17221721 Post 48 for preload specs
Old 04-20-2019, 09:19 PM
  #30
LS1Tech - BTR slow leak down rate lifters. Discontinued
LS1Tech - BTR slow leak down rate lifters. Recommended Preload
Thanks for the heads up. I'll give that a shot.
Quick Reply: My ultimate daily driver
