my truck as it sits right now
Old Nov 5, 2013 | 10:35 PM
casper02's Avatar
Default my truck as it sits right now
Just need to wire up gauges some electrical stuff and gears and truck should be up and ready here are some quick pics
Old Nov 5, 2013 | 10:38 PM
Blown06's Avatar
8 Second Truck Club
Any idea how fast it'll be?
Old Nov 5, 2013 | 10:46 PM
casper02's Avatar
Hopefully with the rear wheels I bought you it will be stupid fast haha jk but should be a low 10 pass may even jump to 9s if everything goes out smooththen the real fun will start when boost starts to increase
Old Nov 5, 2013 | 11:22 PM
oakley6575's Avatar
When will it hit the track and what is the engine/turbo set up?
Old Nov 6, 2013 | 04:29 AM
Noah Burns's Avatar
does the fuel line come from the tank, under the manifold to a T and then to each rail? Was just looking at the pic and couldn't tell if that was in or out.
Old Nov 6, 2013 | 10:41 AM
casper02's Avatar
Should be sometime this month
Engine: 346ci 243 heads stock tbss intake with a 90mm throttle body custom boost cam kit
Turbo kit: its a Tellez Motorsports log style kit with a 4 inch cooler and 88mm turbonetics turbo
Fuel system: running 195lbs injectors with a holley dominator billet pump along with aeromotive billet fiktersand a fuel cell and 10an feed 8an return (the rails get fed from the rear by a Y and the front T goes under the intake towards the regulator)
Drivetrain:nothing fancy just a 4l80 and a full posi with 373 gears
Cooling:running a custom reservoir with a electric water pump with manual tensioner and some trick fans
Suspension:consists of 2way adj coilovers in the front and ladderbars with coilovers in the rear
Full bogart wheels , aerospace catchcan, 2step, meth kit and manual rack kirkey seat and list goes on
Old Nov 7, 2013 | 06:30 AM
slowec's Avatar
Really good choices made IMO. What coilover set up is that? I need my front to lift more.
Old Nov 12, 2013 | 04:41 PM
casper02's Avatar
Thanks and the front is some qa1 double adjustable coilovers
Old Nov 12, 2013 | 05:46 PM
casper02's Avatar
Besides that carms and spindle are stock
Old Dec 20, 2013 | 11:52 PM
casper02's Avatar
Just started it up today
https://www.youtube.com/watch?v=e4VD...e_gdata_player
