My ongoing project
Old May 1, 2010 | 12:28 PM
  #91
Black'Rado's Avatar
played with the bottle posistion more and i got it all mounted up.....
closed...
open...
bottle heater relay
didnt even lose cup holders, just change tray....im going to fill the open area with some abs and you wont even know it was there...
also played with solenoid location and i got a good idea were there gona be, just need to make mounts.
and i think im gona need a shorter main feed line because i have like 7 extra feet that i cant stuff anywere!
Old May 1, 2010 | 12:31 PM
  #92
Black'Rado's Avatar
Anyone use or familiar with the Timing Tuner that nitrous outlet sells that is a timing retard and window switch built in?
Old May 2, 2010 | 09:59 PM
  #93
Black'Rado's Avatar
mounted my solenoids today...
bent up some sheat metal and mounted them to the engine cover braket
hard to see but the nitrous noid is in there...
fuel noid...
cant even see the nitrous side
cant see fuel side or hoses, i loomed the fuel lines so its all hidden
i need to order a shorter main feed line, nitrous outlet plate, put tr6 plugs in, get wideband
Old May 10, 2010 | 05:41 PM
  #94
Black'Rado's Avatar
well today the tru trac split apart and is totally ruined! ill get pics when i pick it up in the mornin, im just putting stock back in for now!
Old May 10, 2010 | 06:09 PM
  #95
Spoolin's Avatar
GFYS and STFU
Carnage pics? What were you doing when it **** the bed?
Old May 10, 2010 | 06:27 PM
  #96
Black'Rado's Avatar
ill get pics soon.
i was jus leavin a stop sign, no romping or nothin just easy drivin and i herd a pop and the rear end started howling bad and i could feel the truck kinda walk sideways when i got on the gas. i thought it was a c clip but tore it apart today and it busted the carrier right were the bearing is pressed on.
Old May 10, 2010 | 06:33 PM
  #97
Black'Rado's Avatar
and one of my rear ssbc slotted rotors is cracked
Old May 10, 2010 | 06:35 PM
  #98
SLOXCAB's Avatar
im thinking the tru tracs sucks ***** cause mine is starting to act up
Old May 10, 2010 | 06:46 PM
  #99
Black'Rado's Avatar
i dont think they suck....i think the sorry piece of **** that sold it to me is junk....im sure you remember about that issue...if not just look up blownfogger540
Old May 11, 2010 | 07:58 AM
  #100
RedHotRodTruck's Avatar
Sorry to hear that..I have a complete rearend with 3.73 if you need it? I think it's a posi.
