My large frame front mount project with two videos
Old Apr 17, 2009 | 03:47 PM
  #341
Nevada79's Avatar
Speaking of back pressure, what are you seeing? I was wondering what was going on with the truck, good to see some more progress. Is that a scotchlock I see on the injector pigtail?
Old Apr 18, 2009 | 12:57 AM
  #342
Wilde Racing's Avatar
How do I change this text
I have not loged backpressure yet (until tonight). I had to make the ebp harness about 10 feet shorter... And NO that is not a injector harness with a scotchlock...
I finally was able to log back pressure. the results of the log shows where all the new found power is coming from...
Just a quick run down...
EBP readings with the STS GT-67 .96a/r
Low boost (6 psi)~15-28psi
High boost (10psi)~28 psi
If I roll into it the boost slow, back pressure would be around 20psi
So with the sts I was seeing a 3:1 pressure ratio
EBP readings with custom front mount s475 1.32a/r
Low boost (6psi)~8psi of back pressure
High boost no results yet, although looking threw my logs I show a peak boost creap at almost 10psi and a peak EBP at 14psi.
I can hardly believe the numbers, but 6psi of front mount feels like 12psi of STS.....
I will post a log up tomorrow if anyone is interested..
Old Apr 18, 2009 | 01:00 AM
  #343
A Low Dime's Avatar
13 Second Truck Club
Thats very interested to read.
Old Apr 18, 2009 | 03:48 AM
  #344
Spoolin's Avatar
GFYS and STFU
Wow, I never thought the numbers would be that LOW...ever. Everything I've read hint's at 3:1 or 4:1 on most systems and 2:1 on good systems. This is great info! Thanks,
Originally Posted by Wilde Racing
But 6psi of front mount feels like 12psi of STS.....
Newbs are gonna see that and go ballistic! You should put a disclaimer on it!
Old Apr 18, 2009 | 04:01 AM
  #345
00Silv4.8's Avatar
WTF, I just went back 7 pages to search for some vid and to catch up... WHERES THE VID!?!?!
haha glad its moving tho! AWESOME!
Old Apr 18, 2009 | 09:16 PM
  #346
1FUNZ71's Avatar
14 Second Truck Club
Thanks I'm not sure if those screen shots are clear... It basically shows the traction (lack there of) at 80 mph...
A video....
S475 front mount Video
Was that by Summit? I have been out of the loop. Looks great. I might be in Reno over the 4th of July.
Old Apr 18, 2009 | 09:19 PM
  #347
A Low Dime's Avatar
http://videos.streetfire.net/video/W...ont_643381.htm
Old Apr 19, 2009 | 02:59 AM
  #348
Ummm. no... that video was filmed on a private track
You better f-ing call me when you come in...
Thanks!
Well, I got the meth tank fitting in place, just need to mount the tank and pump and run the wires. I also got the second waste gate about 85% done. I'll post pic in the a.m...
Old Apr 19, 2009 | 02:37 PM
  #349
vanillagorilla's Avatar
The lower back pressure has more to due with the large T6 housing and BW's better turbine design than moving it up front. To say that moving the turbo to the front will reduce back pressure is misleading. I know you didn't say that, but others will read that.
Old Apr 20, 2009 | 01:38 AM
  #350
Good point I think the 1.32 T-6 a/r had most to do with it, throw in the anaconda down pipe and better design turbine .........
Got the second waste gate on today as well as my meth set-up done. I did a few low boost runs and it hold pretty stedy at 6 psi. At 10 psi I'm seeing 14ish psi in back pressure. the thing is just nuts at 10 psi.
