My large frame front mount project with two videos
Old Mar 1, 2009 | 09:20 PM
  #201
Wilde Racing's Avatar
How do I change this text
It is, and I love doing the work, just frustrating when under a tight time restraint, noise restraint and lacking of tools< which is a big issue for me. I have WAY more money in tools than I do my truck.
Old Mar 1, 2009 | 09:44 PM
  #202
kbracing96's Avatar
Your doing a hell of a job Dusty! I really like how everything is fitting and coming together.
Old Mar 4, 2009 | 09:43 PM
  #203
Thanks Dude.
Well I got a bit more done last night...
I got the frame wax striped, the frame painted, and the ABS harness rerouted. I also finished up my oil cooler support. (pics of that later)
At work, I got my split exhaust, single waste gate flange idea going. Each bank will remain divided. The waste gate valve will seal up (somewhat) at the end of each port, once the gate opens both sides merge, and are bypassed. I'm pretty sure it will work, my only worry is, now the gate wont flow enough to keep boost steady... I'll just have to try it and find out..
Still need a little clean up, but you get the idea..
Old Mar 4, 2009 | 10:01 PM
  #204
kbracing96's Avatar
Open her up a little more with the die grinder You don't need much WG with that big of a turbo and 15+ psi of boost
Old Mar 4, 2009 | 10:14 PM
  #205
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by Wilde Racing
ARE YOU F-ING KIDDING ME???? I WILL NEVER EVER EVER build all this crap in my garage with a cheap *** wire welder, a grinder and a chop saw again
A-effin-men!
Old Mar 5, 2009 | 07:27 PM
  #206
Just Enough's Avatar
Dusty you're a metal sculpting artist. How did you remove the frame wax? The less ecologically sound the method the better (pressure washer filled with benzene). I would like to clean the bottom side of my frame rails.
John
Old Mar 5, 2009 | 08:11 PM
  #207
MikeGyver's Avatar
Why do yous guy want the wax off of your frames? It seems to protect better'n paint.
Old Mar 6, 2009 | 09:00 AM
  #208
The wax is (was) Some what oil coated. I didn't want it to goe down in flames.
John
I used a puddy knife, Carb cleaner, and a few rags.
Thanks guys.
I removed about fifteen feet of wide band wire, and started bending metal for the heat shield. Hopefully I'll have the turbo installed and the fender bolted back up this weekend.
Old Mar 8, 2009 | 09:47 AM
  #209
Got a bit more done last night.
My heat shield
Engine oil cooler mounting, and working on hard line routing.
Turbo oil supply line.
Old Mar 8, 2009 | 04:05 PM
  #210
Well, it's actually going together, finally....
Down Pipe all wrapped up..
Manifold, and turbo support.
Turbo mounted
And the money shot...
PLENTY OF ROOM!
