My 2007 Silverado Build...again
Old Jun 2, 2010 | 05:15 PM
  #81
fastrt's Avatar
11 Second Truck Club
how did i miss this? having a 5.3 with flat tops must be nice!! good looking build man. I want to see what the nitrous numbers are. what spark plugs are you running?
Old Jun 2, 2010 | 05:25 PM
  #82
Phantom's Avatar
11 Second Club
it may be awhile before i get any nitrous numbers on the dyno. i have the tr6's in right now and will prolly use those up to the 150 jets. i do plan on spraying a little more than that though and will then switch to the br7ef's or whatever they are.
Old Jun 2, 2010 | 06:07 PM
  #83
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What size converter are you running? 4.56 gears right?
Old Jun 2, 2010 | 06:12 PM
  #84
Phantom's Avatar
11 Second Club
yes 4.56 gears. 10" converter
Old Jun 2, 2010 | 06:14 PM
  #85
1slow01Z71's Avatar
Guess I should ask the correct question since you answered mine techinically correct What stall speed is it set up for?
Old Jun 2, 2010 | 06:40 PM
  #86
Phantom's Avatar
11 Second Club
it's 3500ish, set up pretty tight
Old Jun 2, 2010 | 08:11 PM
  #87
LS1FREEK's Avatar
13 Second Truck Club
Dude how did you hook up that shift light?
Old Jun 2, 2010 | 08:33 PM
  #88
Phantom's Avatar
11 Second Club
this particular shift lite just has a power, ground and tach wire. power and ground are obviously self explanatory, and the green tach wire went to pin10 on the green connector of the pcm(white wire) and then set it to 4cyl on the lite
Old Jun 2, 2010 | 09:36 PM
  #89
LS1FREEK's Avatar
Cool thanks... I think I might get one too... It looks great!
Old Jun 5, 2010 | 12:29 PM
  #90
Phantom's Avatar
11 Second Club
finally got to spray it last night...she moves out pretty good!
