My 2007 Silverado Build...again
Old Jan 22, 2013 | 10:06 PM
  #751
Phantom's Avatar
11 Second Club
Originally Posted by smokeshow
So it has VE correction using the wideband?
Yessir. It has a table for target a/f that is based on kpa x rpm. The VE analyze adjusts the VE so that it runs that a/f. Then once you have the VE dialed in, you turn on the o2 correction and it will real time adjust like a factor o2 sensor
Old Jan 23, 2013 | 10:53 AM
  #752
LS1FREEK's Avatar
13 Second Truck Club
Damn, that Megasquirt sounds legit! How much would it cost to upgrade to that? Is there a way to run it together with the factory ecm, or would I have to get the MSD 6010
Old Jan 23, 2013 | 10:58 AM
  #753
TTownTech's Avatar
What he said ^^^
Old Jan 23, 2013 | 11:05 AM
  #754
Phantom's Avatar
11 Second Club
You can run it with the factory ECM like parish did way back in the day
Old Jan 23, 2013 | 11:09 AM
  #755
Phantom's Avatar
11 Second Club
Or you can control spark with the megasquirt. It's a pretty awesome unit
Old Jan 26, 2013 | 03:16 PM
  #756
LS1FREEK's Avatar
Hmm, very interesting!! It wires up to the stock coils? Does it support 3bar timing? Too many questions, I'm gonna do some research!
Old Jan 26, 2013 | 04:27 PM
  #757
dirt track racer 81's Avatar
4bar..
Old Jan 26, 2013 | 06:25 PM
  #758
GMCtrk's Avatar
Got the truck switched over to e85 last friday. Had it tuned by friday evening thanks to the megasquirt. It's so awesome. It has a VE analyzer kinda like autoVE on efi live. Tell it to start autotune, start the datalogger, go drive around, cruise, idle, rev, make some pulls. You can make the real time correction and then also have the VE analyzer analyze your entire drive and it will correct the ve for condition you went through. Tuned from idle to cruise to 8# within 3 drives. SOOO awesome. I love it. It's the best thing I've done for my truck.
Idle clip
234/236 .613/.613 111LSA +4 camshaft
s480 1.32a/r 96mm turbine - 4" downpipe
4" pipe back to 4" magnaflow race series round muffler turned down at the axle
850rpm
Turbo Truck Idle clip with exhaust - YouTube
That thing sound nasty.
Any tips for going from gas to E85 tuning wise?
Old Jan 27, 2013 | 04:45 PM
  #759
Phantom's Avatar
11 Second Club
It's probably not the correct way to do it, but I added 20% to the whole VE table and then started driving and let the auto tune do the rest of the work. Idle cruise was pretty close but in boost it actually cut some fuel from what I added
Old Jan 27, 2013 | 06:00 PM
  #760
Get some vids of it on the trans brake on the two step..
