My 2007 Silverado Build...again
#751
Yessir. It has a table for target a/f that is based on kpa x rpm. The VE analyze adjusts the VE so that it runs that a/f. Then once you have the VE dialed in, you turn on the o2 correction and it will real time adjust like a factor o2 sensor
#756
#758
Got the truck switched over to e85 last friday. Had it tuned by friday evening thanks to the megasquirt. It's so awesome. It has a VE analyzer kinda like autoVE on efi live. Tell it to start autotune, start the datalogger, go drive around, cruise, idle, rev, make some pulls. You can make the real time correction and then also have the VE analyzer analyze your entire drive and it will correct the ve for condition you went through. Tuned from idle to cruise to 8# within 3 drives. SOOO awesome. I love it. It's the best thing I've done for my truck.
Idle clip
234/236 .613/.613 111LSA +4 camshaft
s480 1.32a/r 96mm turbine - 4" downpipe
4" pipe back to 4" magnaflow race series round muffler turned down at the axle
850rpm
Turbo Truck Idle clip with exhaust - YouTube
Idle clip
850rpm
Any tips for going from gas to E85 tuning wise?
#759
It's probably not the correct way to do it, but I added 20% to the whole VE table and then started driving and let the auto tune do the rest of the work. Idle cruise was pretty close but in boost it actually cut some fuel from what I added
