ls3 forged+f1a= la joe gibbs new motor
Old Dec 4, 2011 | 01:45 PM
lablackbeast's Avatar
doesn't know what quit means
Default ls3 forged+f1a= la joe gibbs new motor
well like the title says guys, i blew a head gasket not that long ago and came across daryns ls3 forged (6.2) went and picked it up yesterday, it was a bad *** deal, thanks again daryn, well the plans for it is selling the cam it has now, the heads too and slapping some ls9 head gaskets and maybe LSA heads, and specting out a cam for it so it cam take out as much power as it can, the 8 rib is already on the truck, i am also going to pin the crank so the pulley wont get loose no more and try to shoot for 20psi. Hope it holds, what yal think..??
Old Dec 4, 2011 | 01:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Sounds like you will have traction issues at any speed. BEAST!
Old Dec 4, 2011 | 02:07 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What are you going to do about the reluctor wheel?
Old Dec 4, 2011 | 02:09 PM
change it
Old Dec 4, 2011 | 02:10 PM
thanks
Old Dec 4, 2011 | 02:21 PM
2007chevy5.3l's Avatar
Sounds like that will be a fun build and a super fast truck once its done!
Old Dec 4, 2011 | 02:48 PM
slowlsx's Avatar
Sounds like a plan! Those lsa heads will be a good option for you. Don't forget to checkout the Holley Hi ram ls3 intake, it is the best intake I've seen and pretty cheap, should make good power over your intake. 20psi should make close to 900.
You plan to do pump gas and meth or e85
Old Dec 4, 2011 | 03:02 PM
I wanna say e85 since I have the injectors for it, but not sure yet
Old Dec 4, 2011 | 06:09 PM
slowlsx's Avatar
What ya got 120's? 80's won't take you far with that setup.
Old Dec 4, 2011 | 06:14 PM
120s, they are not on yet but I think I ma have with this set up
