ls3 forged+f1a= la joe gibbs new motor
Old Dec 5, 2011 | 12:21 AM
  #21
Blown06's Avatar
8 Second Truck Club
Good luck, man. Should get you in the 9's anyway...
Old Dec 5, 2011 | 12:25 AM
  #22
lablackbeast's Avatar
doesn't know what quit means
we will see what happens, btw what you think i should do for the crank..?? pin or key..?? do you know how to do it.?? i need help from someone thats had experience with prochargers
Old Dec 5, 2011 | 06:50 AM
  #23
Lil brother PI's Avatar
dam going to be nice to see how it does
Old Dec 5, 2011 | 09:48 AM
  #24
LsxCody's Avatar
What are you running suspension wise?
Old Dec 5, 2011 | 10:46 AM
  #25
well it has a 3/5 drop, caltracs in the back, on belltech drop shocks and in the front i have some 90/10s lake wood shocks
Old Dec 5, 2011 | 11:27 PM
  #26
Blown06's Avatar
8 Second Truck Club
In all honesty, anything with an F-series blower needs a key. The pinning kit may work, but if it doesn't the balancer and crank will be ruined.
FWIW, I had the crank keyed on my 346 with the d1sc. You'll probably never see me pin a crank. Especially if the motor is apart.
Old Dec 5, 2011 | 11:35 PM
  #27
do you know who could do it..?? i am going to have to take out the crank anyways since i need to change out the reluctor wheel. So thatll be a good time to key it. Btw whats the difference between the key and pin..??
Old Dec 6, 2011 | 12:17 AM
  #28
08cheyennesc's Avatar
Good luck man,always good to see great procharged trucks.
Old Dec 7, 2011 | 12:25 AM
  #29
Blown06's Avatar
8 Second Truck Club
Its actually called a woodruff key. The key itself is a square bar stock. A square slot is cut in the crank, key gets put in, the balancer gets a square slot cut into the bore. The key is half in the crank and half in the balancer. Best way I can describe it. An engine machine shop should be able to help you out. Nice thing about ls motors is that it doesn't have to be indexed.
Old Dec 7, 2011 | 02:18 AM
  #30
AKlowriderZ71's Avatar
11 Second Hall Moniter
The biggest difference, is that a keyway goes all the way through the balancer (which makes R&R much easier), while the pin only goes part-way through. The square shape of the woodruff key, along with the added length, give it more surface area, which makes it stronger.
I sure hope that makes sense when I read it tomorrow.
