ls2 intake on an ls1 motor??
Old Aug 8, 2016 | 12:31 AM
nathanstowing's Avatar
Default ls2 intake on an ls1 motor??
hey there I'm putting together an lq9 motor with 243 heads and ls2 intake with 90mm tb from a tbss, what do i need to put the ls2 intake on my ls1 truck and where can i get this stuff ? I've heard you need the pigtail for the tb but I'm not quite sure..
Old Aug 8, 2016 | 12:37 AM
FFDP's Avatar
Is it already a DBW truck? Any other information on the setup?
There might be better choices that sticking a car intake on your truck.
The truck intake will be better suited than the car intake if you care about low end torque.
Old Aug 8, 2016 | 12:46 AM
yes its an 03 silverado 5.3 with the electric throttle body , the ls2 intake is off a trailblazer ss and i have a performance throttle body +spacer+ cold air intake so I'm sticking with it + it should have more flow then the ls1 and the throttle body is bigger, my only concern is what kind of wiring do i need to hook it up and have it running properly..
Old Aug 8, 2016 | 12:52 AM
FFDP's Avatar
I think you have your motors mixed up but that's okay.
The LS1 is a 5.7 car motor, your 5.3 is likey a LM7 with a different throttle body/intake than an LS1.
The LS2 truck motor has a TBSS/NNBS style truck intake.
Aside from that I think they make a x-link adapter harness to run it but someone can correct me if I'm wrong. Also toss the TB spacer in the parts bin, they are just another spot for a vacuum leak and don't add performace.
Old Sep 10, 2016 | 11:59 AM
ok got it thanks for advice i will return the spacer..
jbaum02
Jan 22, 2017 11:28 PM
HDhotrod
18
Mar 18, 2016 10:49 PM
Slammed silverado
17
Mar 7, 2016 09:22 AM
The Guy in MY 99TA
Apr 24, 2002 09:21 PM
