L18/4L80e Swap into 2000 RCSB 2wd Build
Old Sep 26, 2016 | 03:56 PM
diggy79's Avatar
Default L18/4L80e Swap into 2000 RCSB 2wd Build
Hey all,
I'm new to this forum, but not new to the GM800 Platform. Done a couple of projects now with my most recent coming to completion, I'm looking for something fun.
This project comes in the way of leftovers from last build. I recently did a Duramax/Allison swap in a 2004 2500 Suburban LT.
For that large swap an entire donor truck was required, so a rolled 2005 crew cab short box duramax 4x4 was purchased. You may be able to see where i am going with this... insert the 8.1L/4L80e sitting on my shop floor.
the best part of this project was the truck i found. sitting for sale with no motor or trans... for 2 grand.!
Again this more of a way to use up some extra parts, so please no "you should just put a 6.0L in" comments please.
The plan:
Swap all electronics from 2000 gen to 2004/2005 Gen wiring.
Motor/trans/ECM/PCM/BCM are all from the 04/05 platform.
Swap then entire interior to dual zone HVAC from duramax. dash, power windows/door locks, heated leather seats, and last but not least the center console.
Thunder550 did a similar project with a reg cab a couple of years ago, but it was a duramax swap.
Just started the tear down and here are some starter pics for you all.!
Later..
Diggy
Attached Thumbnails L18/4L80e Swap into 2000 RCSB 2wd Build-20160922_164816.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-2.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-3.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-4.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-5.jpg
L18/4L80e Swap into 2000 RCSB 2wd Build-6.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-7.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-8.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-9.jpg   L18/4L80e Swap into 2000 RCSB 2wd Build-10.jpg
03blksrt-4
Apr 6, 2017 08:58 PM
whippled 8.1l build
Dec 19, 2012 08:46 AM
Sierra1320
Dec 17, 2011 11:33 AM
tank454
26
Aug 18, 2009 04:26 AM
