Jake's '05 Rcsb s488 4l80 build
Old Jul 30, 2018 | 08:34 PM
  #381
Jake75's Avatar
Originally Posted by NC03GT
Saw someone share your post on fb! Solid *** numbers man!!!
Thank you! I'd like to see it hit 1200 then turn it down to 12-15 psi and just enjoy all the work I put into it.
Old Jul 31, 2018 | 01:43 PM
  #382
Vortec350ss's Avatar
Great numbers!
How does that 88mm drive on the street? Must be pretty laggy.
Old Jul 31, 2018 | 08:12 PM
  #383
Jake75's Avatar
Great numbers!
not at all! Thing spoils up and kicks in real quick.
Old Aug 19, 2018 | 10:27 PM
  #384
Jake75's Avatar
Got the second pump on just need to wire it up and ill be heading back for more dyno time. 2nd pump will be on a 2psi hobbs switch
Old Aug 19, 2018 | 11:29 PM
  #385
brandon6.0's Avatar
should have plenty of fuel this time around! What size feed line to the pumps and to the rails? I just purchased 2 AEM 400s for my truck. I run a dbrods cell as well.
Old Aug 19, 2018 | 11:32 PM
  #386
brandon6.0's Avatar
Edit** never mind on the fuel line size and routing. Saw u posted it a couple posts back.
Old Aug 20, 2018 | 12:15 AM
  #387
Jake75's Avatar
incase anyone else doesnt wanna go digging. I'm running 12an to the inlet of the pumps and -8 out of each pump to a -8 Y fitting out to the rails
Old Aug 20, 2018 | 12:25 AM
  #388
Atomic's Avatar
I have a gauge for that
If you use a straight piece and a 45 on the Y the lines from the pump will be parallel and the line to the engine will be angled up already so its easier to run
Old Aug 20, 2018 | 07:58 PM
  #389
brandon6.0's Avatar
My cell has twin -8 fittings at the sump. U think they could flow enough for twin AEM 400s parralel like yours?? Was gonna reuse my -8 feed and -6 return.
Old Aug 20, 2018 | 09:13 PM
  #390
Jake75's Avatar
not sure I'd call aem. Magnafuel recommends 12an on the suction side of these pumps to prevent starvation
