ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Jul 18, 2018 | 04:32 AM
  #301
smokeshow's Avatar
Mod with training wheels
First thought is plug gaps if it idles like **** in park/neutral, barring any calibration issues... Would need to see data to know for sure, but check that plug gaps aren't too tight. I'd also ditch the MAF. Even if it has enough resolution to handle the flow, when boost comes in that charge pipe will flex and throw off fueling because the airflow through the MAF will contort.
Old Jul 18, 2018 | 07:17 AM
  #302
ILuvJDM's Avatar
The plan all along has been to make well over 500, but I was told MAF is good for 500-550whp. As I've said before, when I switch intake manifolds and TBs and have to build new charge pipes, I will then switch to SD.
Plugs are gapped at 0.028 and I confirmed when I pulled them.
Old Jul 18, 2018 | 07:40 PM
  #303
ILuvJDM's Avatar
Used a borescope to check out cylinder number 8, since it was lower than the others, and it appears fine. This picture shows.some crosshatching I thought was cool
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-wl3nddg.jpg
Re-attached the plug wires and made sure they all made a solid connection. Also used some extra wire from the turbo blanket to hold up the wires off the manifold and get an air gap
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-8lsl0ah.jpg
Full finger gap
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-x3ntzlp.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-q5bp9mk.jpg
Tuner sent me a new file to test and it now idles beautifully. Very rich, but no longer surging and dying and popping, so I feel we are making progress.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-uvcynjt.jpg
Made a wiring harness for my radio install
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-mmc2xcd.jpg
Old Jul 18, 2018 | 08:14 PM
  #304
arthursc2's Avatar
What stereo did you go with?
Old Jul 18, 2018 | 08:58 PM
  #305
ILuvJDM's Avatar
Pioneer AVH-X3800BHS I think
Old Jul 18, 2018 | 09:00 PM
  #306
FFDP's Avatar
You don't even have to remove the MAF to switch to SD if you wanted too. It just requires failing the MAF within the tune to use speed density and using a 2/3 bar OS with a correct MAP sensor.
Old Aug 6, 2018 | 07:46 PM
  #307
ILuvJDM's Avatar
Well it's been a long couple of weeks. Decided to start the audio build since I had to mail my gauge cluster out again because they didn't activate the DIC.
Shortly after that, we had some emergency issues with our dog and we had to take her to Texas A&M and get a pacemaker installed. Surgery went well and she is back home recovering now. It cost about as much as a small car, but you do what you gotta do for your beloved pets.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dmr0p98.jpg
After the surgery with her bandage. They put the pacemaker under the skin of her neck
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-zkbnpfm.jpg
Anyway, back to the truck mods
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hvhyhea.jpg
Glued some wood to the back wall
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-oojtsk0.jpg
Sound deadener
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-imxpwgo.jpg
Box installed and screwed into the wood strips to it doesn't move around
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-d9yec2x.jpg
RCAs run on the passenger side
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-yb56chh.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-0efnwfb.jpg
Drivers side complete
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-nx8mat8.jpg
Engine side complete
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-t3gsvup.jpg
Slowly making progress
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-dyualgu.jpg
Made some brackets for the second amp
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-hlkjfjg.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-r11lxk2.jpg
Fail
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rl0ztdg.jpg
Building a harness for the SMD meters
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-kim15en.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-upd4x93.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-g84zrcg.jpg
Moved the amp back 1/2" which is perfect fit
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-i5s18su.jpg
SMD meters and gain ***** mounted
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-2759mnu.jpg
Close the lid and it's all hidden
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-lta4d2j.jpg
Old Aug 6, 2018 | 09:39 PM
  #308
hutch311's Avatar
Clean work as always. Appreciate the updates.
Old Aug 7, 2018 | 01:53 PM
  #309
The_W's Avatar
Nice quality work. Glad your dog is doing well also, mine is a extension of the family so your not alone haha.
Old Aug 7, 2018 | 03:26 PM
  #310
arthursc2's Avatar
I am glad you guys paid for the pupper! I'd sell my truck if I had to in order to cover costs and keep my pets.
Liking the audio install. 2 amps is ******* major work lol
