Graeme's Daily Driver 2003 4x4 Build
Old Dec 28, 2016 | 10:27 PM
  #591
GM1697's Avatar
Anyone wanna take a look at this log and tell me why I will get REP driving the first few minutes after cold starts??
at 1:32 and 1:42
GraemeTune-boost-2-bar-83-injectors-10.hpt
robfuckedme_episode54.hpl
Old Dec 28, 2016 | 10:54 PM
  #592
FFDP's Avatar
A guess is the P0068 problem, is that a code you are getting when it enters REP?
Most just modify the P1514/P0068 table by 1.25 to 1.5 untill the problem goes away. It seems to happen in cold weather.
Also something that I never understand is why people put the MAF DTC's to NO MIL LIGHT, the whole point of speed density tuning is to tell the computer that the error happened straight away. Telling the computer to revert to speed density on first error is the "first" thing the computer should know even though you have the MAF fail high set to 0hz. Maybe it's just a pet peeve of mine and it's such a simple change to make dead sure the MAF sensor is never a factor, then just disable the SES boxes.
Old Dec 30, 2016 | 09:09 PM
  #593
GM1697's Avatar
Yeah that's the code. I'll look into it.
Also setting the MIL to first causes my truck to REP instantly.
Old Dec 30, 2016 | 09:10 PM
  #594
GM1697's Avatar
Added a 145amp alt today.
Old Dec 30, 2016 | 09:18 PM
  #595
BlackGMC's Avatar
Resident Retard
SC looks good.
Old Dec 30, 2016 | 10:50 PM
  #596
dantheman1540's Avatar
Looks really good!
Is that alternator a direct swap?
Old Dec 31, 2016 | 12:01 AM
  #597
GM1697's Avatar
Thanks guys.
And yeah the alternator is a direct swap, it came in the 04+ trucks.
Some say you need a longer belt, but because I have the adjustable idler it didn't make a difference.
Old Dec 31, 2016 | 08:05 AM
  #598
flatblack83's Avatar
Originally Posted by GM1697
Thanks guys.
I did this mod before my supercharger, with the stock setup and belt you can get away without a new belt but its a fight to get the belt on. Are they 90mm idlers..?
Old Jan 1, 2017 | 12:39 PM
  #599
GM1697's Avatar
Yup 90mm idlers.
Old Jan 3, 2017 | 01:31 PM
  #600
03sierraslt's Avatar
Did you get REP sorted out?
