Graeme's Daily Driver 2003 4x4 Build
Old Nov 25, 2016 | 09:02 PM
  #541
LOWRIDERGMC's Avatar
Originally Posted by GM1697
To be honest I haven't assessed spark or trying to pump it full of starting fluid. I assumed if I got the cluster to function then the issue would be resolved.
You are probably right! It has to be something stupid electrical...So find what's not connected, I want to hear this thing run! Did u try disconnecting where you tied in circulator pump?
Old Nov 25, 2016 | 09:05 PM
  #542
Atomic Performance's Avatar
Former Vendor
If you need a new tuner I know a guy
Old Nov 25, 2016 | 11:04 PM
  #543
GM1697's Avatar
Yeah it's on same circuit as my aftermarket gauges. disconnected all of them. doesn't make a difference.
  #544
GM1697's Avatar
Baha im sure you do
Old Nov 27, 2016 | 05:18 PM
  #545
GM1697's Avatar
well boys. I spent the weekend following every wire, checking every fuse, and it was basically a waste of time.
The cluster started functioning once I hooked up jumper cables, which is strange but i'll take it. I'can't believe the truck would crank but not have a working cluster?
Then next I thought I had a tune issue... I like blaming Rob for my problems. Looks like the tune is fine.
Finally I had disconnected my aftermarket guages in my frustration, but after hooking them back up I noticed fuel pressure was 0. So I pulled out the sensor, and the fuel rails are bone dry.... I think this is the issue. Fuel pump is working which leads the problem to this bad boy!
For those who are familiar with these piece... you'll notice that the feed and return are switched. I bought it used and didn't think much of it, just slapped the lines on and hoped for the best.
So looks like thats the issue all along. Let the roasting begin.
Also if someone who also has this fuel block can confirm my suspicion that would be excellent. I'm outta time to work, headed back to AZ for 10 days.
Old Nov 27, 2016 | 05:31 PM
  #546
flatblack83's Avatar
I removed that and blocked it off, feed the passenger rail and use the drivers as return. Plumb your regulator at the end of the pass rail and connect it to the return... all fixed. Your stock fuel feed line should make it to the pass side. A few fittings and a short piece of line and your done.
Old Nov 27, 2016 | 08:19 PM
  #547
Atomic's Avatar
I have a gauge for that
Just gonna leave this here...
Old Nov 27, 2016 | 08:51 PM
  #548
Vortec350ss's Avatar
Face in palm... thats why i asked you about your gauges. Specifically the fuel pressure right off the bat.
Old Nov 27, 2016 | 10:57 PM
  #549
GM1697's Avatar
I think we can all agree that this has been a learning experience for us.
Old Nov 28, 2016 | 01:01 AM
  #550
Richardman1992's Avatar
I think we can all agree that this has been a learning experience for ME.
Fixed it ha
