Geareater's Build Thread
Old Nov 13, 2012 | 08:09 PM
geareater's Avatar
Default Geareater's Build Thread
Been reading through the forums for a while now, finally in the last few months I got the itch. Started with a stock 2004 5.3 Z71 with about 70k on the clock. Went big with a good deal on a low mileage LQ9 from the salvage yard in Holland.
Swapped in yellow springs and LS6 cam.
All buttoned up
Out with the old. Didn't really get many pictures of it going in because I ended up doing it alone. Went pretty quickly regardless. I threw in a 34" radiator and efans at this point too, I think I went with the Nelson harness. Also went with the 145 amp and underdrive pulley.
Shortly thereafter swapped on the TBSS intake with LS6 throttle body, plus the x-harness. Still trying to figure out where I want to permanently put that.
Then the hydroboost system with hydroboost ps pump.
As she sits today, just tonight I sprayed the front valence flat black. Have yet to take a picture though. I have a set of LPP headers in the mail somewhere, I'll be getting them installed next. From here, I'll be doing more research on either FI or NO2, and will be looking for a cheap 4l80e, and a better locker. I've installed a servo and raised the line pressure and shift points with my tune, my 60 has been doing me well, but its only a matter of time. I almost locked down a sweet trade for a P1SC1 kit but it fell through. Let me know what you think.
Old Nov 15, 2012 | 12:51 PM
gmstrong's Avatar
truck looks great,what kind car did you get the efans from?
Old Nov 17, 2012 | 09:01 AM
geareater's Avatar
Thanks, just the standard 05+ truck efans, I got them from LKQ recycled parts.
Got my LPP Headers installed this weekend, only had a little hiccup with the front drive shaft ujoint bolts touching the driver side header, ball pin hammer fixed all that. Here's an open header video
Old Nov 17, 2012 | 09:04 AM
GMCtrk's Avatar
Nice. How do you like the hydroboost?
Old Nov 17, 2012 | 09:22 AM
geareater's Avatar
The hydroboost is incredible. I've driven vehicles with vacuum powered brakes all my life, this is a difference of night and day. I encourage anyone to do that swap.
Old Nov 17, 2012 | 09:27 AM
GMCtrk's Avatar
Yeah, the vacuum brakes are terrible. I'm trying to get my hands on a booster at this time.
Old Nov 17, 2012 | 09:35 AM
geareater's Avatar
At the jy here outside Austin there were a few Suburbans and State Trooper Tahoes with the system in it, all you really need is the booster, pedal, and high pressure lines. I'm sure you could have one from a good jy around H-town within a couple hours. Everything else will work from your truck. Unfortunately all the yards around here like to cut their harnesses and hoses, its unacceptable. On Atomic's hydroboost swap thread I put the part number for the high pressure lines from Oreilly's for cheap, just takes a little tweaking to get them to fit. The whole swap including the new PS pump I got probably took about 3-4 hours.
Old Nov 17, 2012 | 09:45 AM
RibeiroBJJ's Avatar
Praise The Lowered
Nice Job, And cool truck..I actually like your truck stockish hieght...Sounds good too
Old Nov 17, 2012 | 06:03 PM
geareater's Avatar
Thanks! I was thinking of just pulling out the lift blocks in the rear, or maybe even a 2/4 drop. But I have a set of bilsteins on there I love so much.
Old Nov 17, 2012 | 06:32 PM
GMCtrk's Avatar
I sealed the deal on a booster and brake pedal from a yard here in houston over the phone. It's all out of an 02 Escalade EXT. BUT, he told me they cut the lines from the booster! Well, except the Booster to power steering pump hard line. I am getting that one. So I have to see when I go there Monday if they can source the other lines from another vehicle on the yard. I'm not worried about the low pressure return hose, I can get that anywhere for cheap.
My only real concern is regarding the master cylinder. My truck has the square looking resevoir whereas the Escalade has the larger rounded one. I have come across a couple posts of the master cylinder holes not lining up with the hydrobooster studs. I'm really hoping the two are interchangeable and just have different reservoirs.
