First turbo install...
Thanks for the reply Oakley. I was actually debating on tapping mine on the front of the pan. Might go that route.
Been waiting on a few parts so decided to throw the new tranny cooler on. Hopefully this keeps the temps down when hauling my boat this summer...
Also did the corvette servo swap. Should get the intercooler mounted tomorrow...
Nice list of mods. The issues w the on3 are plug wires and pipe fitment. It you can get around those you'll be good.
I'd move the Trans cooler either up as high as possible in the middle or off to the side a bit so the air hits it directly instead of through the IC first.
Thanks for the reply Choda..I might play with it some more and try to find a better spot for the intercooler. I'm going to start running the pipe tomorrow and hopefully have it all buttoned up by the end of this weekend. Any recommendations on plug wires? I remember reading a thread on here and someone saying they had some good luck with a set they bought from napa.
Hoping to have this all finished up tomorrow. Got a little behind this weekend being that it was my hometown festival
Can anyone point me in the right direction for the map sensor I need? I've heard cobalt ss and seen a few different part #'s...
Well had some issues when drilling the pan. After tapping I attempted to install the brass fitting and it decided to snap off half way through...so in the end I pulled the pan cleaned it and had a fitting welded in...still have alot to get done and time has been an issue with my work season starting...procrastination!!!
