Figured I should start this.
Old Mar 31, 2014 | 09:05 PM
  #31
oakley6575's Avatar
I like it man. Clean install on the rear bumper. If you get back under the truck sometime, is there any way you could measure the distance from the top part of the fuel bucket assembly to the bed?
Old Apr 2, 2014 | 06:26 PM
  #32
silverado.408's Avatar
No problem I'm pulling the trans this weekend.
Old Apr 2, 2014 | 08:58 PM
  #33
oakley6575's Avatar
Nice. I really need to start working on mine and need that measurement so I can order parts.
Old Apr 11, 2014 | 06:20 PM
  #34
Today I got my th400 back so I threw it in to get an idea of what I need to do with the cross member situation , and also measure up for the drive shaft. And for a quick side project I mounted my trans cooler in the rear next to the battery box. Fit perfect.[IMG][/IMG][IMG][/IMG]
Old Apr 11, 2014 | 06:21 PM
  #35
Old Apr 11, 2014 | 09:13 PM
  #36
oakley6575's Avatar
Looks good bud! Did you get a chance to measure the fuel bucket clearance?
Old Apr 11, 2014 | 09:29 PM
  #37
Yep[IMG][/IMG][IMG][/IMG][IMG][/IMG]
  #38
That is flush against the bed
Old Apr 11, 2014 | 09:53 PM
  #39
oakley6575's Avatar
You the man. Thanks a ton! Looks like the bed ridges are roughly 1"? And one of the ridges sits right above the hat extrusion. So I might have 1-1/2" clearance to run a -10 feed out of the top of the hat extrusion...
Old Apr 11, 2014 | 11:26 PM
  #40
My thought buy an extra assembly cut off the evap hat weld a flat piece in then tap into that it will drop it down a little over an inch then you should clear
