DIY Denali build
Old May 29, 2018 | 12:25 PM
000martin's Avatar
Originally Posted by RedXray
Sounds really good. I was on the fence between the 220/224 and the 228/230. Now I'm kinda thinking I should have went with the smaller grind for my LQ9 build which is going in the truck, when my mail order tune gets here this week. Thanks for the clips, looking forward to your turbo install. FI is also on my list after a rear gear install.
im tryin to get all parts in a pile so when I tear it down it will for a week instead of a month. I’ll keep y’all updated. I think I’m gonna use a corvette regulator to make it return style instead of using different rails completely
Old May 29, 2018 | 12:30 PM
Vortec350ss's Avatar
Sharp truck!
Old May 29, 2018 | 01:27 PM
000martin's Avatar
Sharp truck!
preciate man. I’m out of the loop. You sold your 05 Denali didn’t you?
Old May 29, 2018 | 01:50 PM
I haven't sold it yet... its still a roller. I haven't had time to put it back to stock yet. Soon enough. It deserves a good home... its only got 76k on it and the interior is flawless. Still have all the factory driveline parts to go in.
Old May 29, 2018 | 02:23 PM
000martin's Avatar
At the height of that build what was the best et it would run on a good night. It was making 700+hp correct?
Just trying to get a ballpark figure for mine.
I still think I’m gonna put a true 4x4case in there and have selectable 4wd.
Old May 29, 2018 | 03:26 PM
I never got the most out of the 2300 before it was out the door so I wont even count that... but with the 1900, cam and bolt on mods with the 80e it went 11.43 at 118.5.
I would keep the AWD case. Its strong as hell.
Old May 29, 2018 | 05:04 PM
000martin's Avatar
something about blowing the tires off at 50mph is attracting. But traction is name of the game. I’ll probably keep it. Can’t find a whole lot of detailed info for the 80e swap. I know you have to swap input shaft on the tcase. Is there a lot involved?
Old May 29, 2018 | 05:42 PM
Its easy, its just expensive to get that shaft done...
Old May 29, 2018 | 10:17 PM
hutch311's Avatar
In the grand scheme of the build the price of the modified input gear adapter isn't terrible. When I did mine I had the transfer case gone through at the same time. Time2Kill is the guy I got in contact with for the input gear adapter.
Old May 29, 2018 | 10:38 PM
000martin's Avatar
plenty of info for the trans swap out there, I meant not a whole lot of info for the input shaft stuff on the transfer case
