Can't stay stock!
Old Jul 19, 2011 | 08:11 PM
  #71
Mangled03gmc's Avatar
Baltimore Whore
Hey man you do it how you want, but you said this the best in the thread you posted in
''You can take this approch but it will cost you lots of money to show your self what we are telling you''
Basically just do it rite, instead of trying to reinvent the wheel, scab it up..
Old Jul 19, 2011 | 11:43 PM
  #72
BLK WDO's Avatar
buy bag mounts....weld to frame. buy lower bag mounts.....weld to rear end. its that easy as sure as **** safer then what you are thinking.
i told ya'll to play the waiting game
Old Jul 20, 2011 | 01:23 AM
  #73
99LsSilverado's Avatar
Originally Posted by custm2500
If spring steel could be welded(seemes like it can't) how would it not be right. The same ring was made my GM to locate the spring and expected to last 20+ years and millions of spring movements. So I am using the same ring to do the same job, the only differance is the fact that there is air bag between the coils and not more steel coils.
You are changing the properties of the steel to like its been said making it brittle. Yeah you could heat treat it but it wont be the same as steel purpose made for the part. I would scrap the idea and buy the parts and weld them on.
Old Jul 20, 2011 | 01:41 AM
  #74
AKlowriderZ71's Avatar
11 Second Hall Moniter
Lots of good advice being given here, in regards to properly installing those bags. I hope the OP is catching on.
There are some things that should be "done right" and suspension is one of them.
Old Jul 20, 2011 | 07:51 AM
  #75
Spoolin's Avatar
GFYS and STFU
What about brakes and throttle bodies? How bout frames, are those important or can we cut massive holes in them and still be fine?
Old Jul 20, 2011 | 08:13 AM
  #76
outlawz2004's Avatar
Old Jul 20, 2011 | 11:23 AM
  #77
Old Jul 20, 2011 | 12:38 PM
  #78
03blackout's Avatar
I usually lurk around and never post but this is just too good to be true.....
Old Jul 20, 2011 | 02:39 PM
  #79
rjwz28's Avatar
Man Motor club
Link to OP's other build?
Old Jul 20, 2011 | 05:33 PM
  #80
BLK WDO's Avatar
links
