Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Oct 9, 2010 | 09:53 PM
  #261
1989k1500's Avatar
The cage looks great!
Old Oct 10, 2010 | 03:26 AM
  #262
Blown06's Avatar
8 Second Truck Club
Originally Posted by custm2500
That rear looks so nice I just wish you would put it on a shelf and put a 9 under the truck.
I really hope for you and the sake of "don't fix it if it ain't broke" the axle gets you some miles and passes but I would be chewing my nails off if I were you.
I really aspire to someday be proud to show picks of my truck and consider them near the level your truck is at of fit, finish, and quality.
P.S. That is allot of switches for under-truck neon!
...and under hood neon, and in cab neon, and in bed neon, and wheel well neon. That makes 5 neons for 5 switches.
Originally Posted by blown02408
Until you get your new engine built, do you care if I borrow the F2 and break it in for you? lol
I don't mind at all.................It will require a deposit though.
Originally Posted by vicalma03
Damn looks really good! It looks like the cage isn't in the way at all.
Thanks. I was looking at the pictures before I posted them up. I didn't post all of them but, in most of them you have to look for the cage. It blends in nicely.
Old Oct 10, 2010 | 07:05 AM
  #263
MADMAN's Avatar
Head Fabricator
Its coming together nicely.
Old Oct 12, 2010 | 09:11 PM
  #264
double047's Avatar
14 Second Truck Club
Man I love this build.
Old Oct 13, 2010 | 10:04 PM
  #265
Slay0r's Avatar
sick build thread
Old Oct 16, 2010 | 03:40 AM
  #266
Blown06's Avatar
8 Second Truck Club
I'd just like to take a moment to thank GM for that bad *** coating they put on the truck frames.
I got tired of looking like a grease pit everytime I worked on anything underneath the truck so I decided last weekend to strip all that **** off the frame before I painted the 4-link brackets and bracing that madman welded in. So I started at the back and started working forward. Seems like the more I get off the more there is. That **** is nasty and gets everywhere. I've been using a razor blade to get the bulk of it off then scrubbing with brake clean and a towel. This is the best method I've come up with, although I did break out the 4000psi power washer today and hit it with the 25* tip. It gets if off, only problem is that it blows it all over everything else. Anyway, I've spent about 12 hours scrubbing on the frame and have about 90% of it done, ruined two pairs of shorts, 3 shirts and the wife let me hear about that **** getting tracked into the house. I've used about 8 cans of brake clean so far and I'm pretty sure I've killed about 40% of what brain cells I had. I've breathed enough brake clean fumes that I'm pretty sure I'm immune to HIV now and my lungs feel like they're dryer than the Sahara. Lotion on my hands just turns to powder. I've been in the house now for about 3 hours and I'm pretty sure I'm having withdraw symptoms as I now have a chemical dependency for brake clean. Thanks GM and sorry for the rant!
Old Oct 16, 2010 | 05:23 AM
  #267
custm2500's Avatar
Ph.D. in HUBRIS
Well less brains sound like an excuse to spend event more money! Not sure where you can upgrade anything on this truck but I am sure you can find something.
Old Oct 16, 2010 | 07:43 AM
  #268
vicalma03's Avatar
Should have used Aircraft Paint Remover. Just coat the frame, let it sit and scrub it off. You could have saved your remaining 40% of brain cells!!
Old Oct 16, 2010 | 10:15 AM
  #269
walledition's Avatar
jajaja just doesnt sound to be easy.... keep up the good work and post some pictures.... that is ONE bad *** truck already!!!!
Old Oct 16, 2010 | 01:40 PM
  #270
Spoolin's Avatar
GFYS and STFU
Is that the stuff that you can't let touch your skin? I've heard of it but not sure if that's the one.
