Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Nov 22, 2015 | 10:57 AM
  #2041
BlackGMC's Avatar
Resident Retard
So ehat are the details on the dual fuel rails?
Frank does nice work, he is like 5mins from my house.
Old Nov 22, 2015 | 04:51 PM
  #2042
Atomic's Avatar
I have a gauge for that
Need lots of flowz with meth!
Old Nov 22, 2015 | 05:40 PM
  #2043
BlackGMC's Avatar
Resident Retard
Ahhh. Gotcha. What size injectors you gonna run and what pumps?
Old Nov 23, 2015 | 01:09 AM
  #2044
Blown06's Avatar
8 Second Truck Club
Twin ID2000's per hole. At 90 psi they flow near 300 lb/hr each so I'll have the capacity for around 600 lb/hr per hole, give or take. Won't really need near that with this janky motor, but it will give room to grow. You can do a lot with 4800 lb/hr of methanol.
Honestly, I could probably get by with the single ID2000's at 90 psi as I'm guessing it'll need somewhere between 2000 and 2200 lbs of fuel at full power. But I'm giving myself some room to play and also, I'll likely be running this thing at the normal 43 psi of pressure for now.
Pump is an Enderle 990. I think it's good for around 15 gallons/minute.
Morris said the blower mod should help tremendously, so with the total changes I've got some good expectations. Not high expectations though for obvious reasons.
Old Nov 23, 2015 | 01:13 AM
  #2045
Blown06's Avatar
8 Second Truck Club
I've run into several issues with parts lately and it is keeping me from making any decent progress. I've been working on a trick as **** balancer that is almost done, you guys will like the pics of that.......then this intake needs to go back for "an adjustment". Once I have those two things behind me, I'll be back to where I was near a month ago and can make some decent progress.
Old Nov 23, 2015 | 08:00 AM
  #2046
Atomic's Avatar
Are you talking about a 90psi base pressure?
Old Nov 23, 2015 | 08:45 AM
  #2047
George C....'s Avatar
Formerly ScreamingL
You remounting blower in bumper or grill with that bell mouth
Old Nov 23, 2015 | 05:55 PM
  #2048
BlackGMC's Avatar
Resident Retard
What is the benefit of running the FP that high? Is it a meth thing?
Old Nov 23, 2015 | 05:57 PM
  #2049
Formerly ScreamingL
Its a alcohol fuel thing, some even run 120 base
Old Nov 23, 2015 | 05:59 PM
  #2050
BlackGMC's Avatar
Resident Retard
Wow that is crazy. So alot of volume and pressure with meth.
