Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Sep 17, 2015 | 12:42 PM
  #1981
03regcab sierra's Avatar
Originally Posted by sprayedenali
i have the MT 29s on mine and like them
I'm running the 29" et front on one of my twin turbo trucks. No complaints at all 👌😊
Old Sep 18, 2015 | 12:46 AM
  #1982
Blown06's Avatar
8 Second Truck Club
lets see...
you can buy one for 50-75k, then track rental is 10k/day. so with travel and all youre looking at around 60-80k!
Is it cool if I bring cash? I'm not much for the banks/irs/government knowing how much bread I've got.
Old Sep 18, 2015 | 08:45 AM
  #1983
sprayedenali's Avatar
nothin less than a twenty!
Old Sep 19, 2015 | 12:47 AM
  #1984
Blown06's Avatar
8 Second Truck Club
I commissioned Frankenstien to hook me up with an intake manifold with dual rails. So at first I told them start with a super vic, I want dual rails, mill the top off and make a bad *** bolt on billet upper.............I got the quote and nearly threw up. In the end the most economical thing to do was start with a Mast with a 4500 flange. They are gonna set it up with dual rails and a nice billet elbow. Should have it by the first of next month. Still trying to decide what I'm gonna do about injectors. Right now I'm leaning toward just buying another set of ID2000's. 16 ID2000's at a base of 90 psi should be able to move a **** ton of fuel and support some big power. Next week I'm gonna get the Enderle 990 pump on the way and commission AEI Inc. to build me a mount to work with the wide *** cog pulleys.
I started my for sale list..........so stay tuned!
Old Sep 19, 2015 | 07:19 AM
  #1985
silver-mod-o's Avatar
Hunt&Fisherator
Surely enough fuel to send the ol 'janky' 408 to its grave!!!!
Old Sep 19, 2015 | 09:29 AM
  #1986
George C....'s Avatar
Formerly ScreamingL
Are ID capable of running that high of base?
Ya the mast intakes are sweet but keep in mind Mast is slow with delivery....a quote of 2 weeks turned into 6 weeks for my heads and you will need to call daily
Old Sep 20, 2015 | 12:47 AM
  #1987
Blown06's Avatar
8 Second Truck Club
Poor thing doesn't have a chance. I do have a bit of a different plan this go round though. Last time I was just crazy hardcore about getting it to run a number at a low boost number and fucked it up with timing. This time, I'm gonna leave the timing alone and see if the F2 will push near 40 psi.
ID's will work with up to 9 bar of pressure differential.
Frankenstien called Mast before we settled on a final plan for this very reason. They had a few on the shelf.
Old Sep 20, 2015 | 01:04 AM
  #1988
Blown06's Avatar
8 Second Truck Club
Welded up some mounts for the new engine limiters. Pics......
Old Sep 20, 2015 | 08:02 AM
  #1989
Formerly ScreamingL
Mast said my heads were on shelf to....still took long
Also welds are looking good, can see youre using SS filler
Now change cup angle some and tighten up the puddles. This will give you a stronger weld ....you look between the puddles youll see deep points....those points lead to possible tears
But making solid progress!!!
Old Sep 20, 2015 | 08:14 PM
  #1990
why not low impedence injectors?
