Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old Mar 9, 2014 | 12:50 PM
  #1261
Atomic's Avatar
I have a gauge for that
Yea not even close man....turbos take a LOT of power to drive, just slightly less than a procharger.
Just for comparisons sake, the inducer on an F2 is 114mm and exducer is 171mm. A PT114 turbo has a 114mm inducer with a 141mm exducer. Dont know what the max speed is on the turbo, but I bet its pretty close to the F2.
They are essentially the same thing, centrifugal compressors. The procharger is driven off a belt from the crank, the turbo from an air turbine in the exhaust.
Old Mar 9, 2014 | 01:19 PM
  #1262
silver-mod-o's Avatar
Hunt&Fisherator
I was referring to your front wheels... They look beadlocked in those pics, or are they just 2 piece wheels? If so, ignore my retardation and move along
Old Mar 9, 2014 | 11:58 PM
  #1263
Blown06's Avatar
8 Second Truck Club
Retardation ignored.
The are 3 piece wheels from Bogart, bolted together in the center.
Old Mar 10, 2014 | 12:02 AM
  #1264
Blown06's Avatar
8 Second Truck Club
Originally Posted by custm2500
Maybe another thread would be a place to get a bit deeper into this but procharger requires power to make power, turbo takes very little event at extream hp levels.
So at the same PSI you should net less hp correct? Only a dyno will give us the final answer, and the track will let us know who can run fastest on any given psi.
This is a killer truck and I am not taking away from it but I don't see a logical explanation how it could be better then a massive turbo on the same long block. I would think a properly set up turbo will make similar or more boost at the line and should spool as fast as the charger or faster. Things don't always work out in the real world like they do on paper.
From some testing posted on the bullet, if I remember right it takes several hundred hp to spin an F2. I'm gonna doubt that a huge turbine side is gonna rob that kind of power. Who knows though.......
Would I be quicker with a turbo.........probably not.......I don't know how they work and my eyes are round. I'd probably screw it all up.
Old Mar 10, 2014 | 12:17 AM
  #1265
smokeshow's Avatar
Mod with training wheels
Turbos spin a lot faster than centri blowers. And you could never really dyno test them for comparison, as there are other variables you'd have to change to optimize output from each forced air application... For a turbo to really shine above a procharger, the turbine has to get pretty huge. High backpressure (faster spooling) turbo applications can certainly rob a significant amount of power though.
Old Mar 10, 2014 | 12:31 AM
  #1266
Atomic's Avatar
F2 has max speed of 65,000rpm. Not that thats the choke rpm, its probably the limit of a good efficiency zone. True max rpm where you get compressor choke and/or rub on the housing is probably 70-75k. A turbo compressor of the same size will have the same limits for the same reasons, because like I said, on the cold size, they are the same thing.
Old Mar 13, 2014 | 12:13 AM
  #1267
Blown06's Avatar
8 Second Truck Club
I think for my 3000th post I'll bump my own thread.
Old Mar 13, 2014 | 12:51 AM
  #1268
99 lives's Avatar
Hell yeah, Travis.
Old Mar 13, 2014 | 11:41 PM
  #1269
Blown06's Avatar
8 Second Truck Club
Killer pics by the guys at Houston Performance Trucks.
Old Mar 13, 2014 | 11:50 PM
  #1270
oakley6575's Avatar
Wow those are great pics. Good looking truck for sure
