BlackGMC build take 3 - Supercharger Time
Old Jul 26, 2016 | 11:19 PM
  #561
BlackGMC's Avatar
Resident Retard
So the main reason for the dual aeroforce gauges is to supports some extra sensors. I bought another iat sensor for the the intake tube. I want to see what temp the incoming air. I have 2 coolant temp sensors to see wht the temp is in the intercooler tank and what the temp is leaving the heat exchanger.
That should give me enough to play with and to see if all this crap is worth it. Time will tell.
Old Jul 27, 2016 | 10:57 AM
  #562
Vortec350ss's Avatar
It will be very interesting to see all that for sure.
I really am blown away at the improvement at cruising speeds. Great work.
Old Jul 27, 2016 | 11:11 AM
  #563
BlackGMC's Avatar
Resident Retard
Well you saw the results of running with the sysyem unhooked. I had no idea it could impact it like that.
Old Jul 28, 2016 | 09:49 PM
  #564
BlackGMC's Avatar
Resident Retard
I made a couple shake down runs in boost today. Only 10-12psi 60-90mph The new rear suspension setup and tires held 2nd just fine. No spinning. Meth psi hit about 100psi. IATs initialky jumped about 15* and held that. The recover time was insanely fast like 4-5 seconds. I got a few bugs to work out. All in all i am happy.
More to come.
Old Jul 28, 2016 | 09:58 PM
  #565
BlackGMC's Avatar
Resident Retard
Can you see the heat exchanger???
Old Jul 28, 2016 | 11:26 PM
  #566
Can we see it... If I didnt know better I would have assumed it was an aftermarket radiator.
Does it block airflow to your actual radiator at all? Anything noticeable with coolant temp?
Old Jul 29, 2016 | 04:15 AM
  #567
03sierraslt's Avatar
So where are you putting all these guages?
Old Jul 29, 2016 | 09:38 AM
  #568
05stepside's Avatar
Wow! Looks awesome Corey! I need to come over when we both have time in our schedule. I'd love to see all the changes in person and maybe I could experience the 10-12 psi????
Old Jul 29, 2016 | 09:41 AM
  #569
BlackGMC's Avatar
Resident Retard
It is actually running about 4-5* hotter than it used tooo. AC still blows cold thou
2 in the pillar
2 in the cubby next to the cluster
3 in the console.
Old Jul 29, 2016 | 10:53 AM
  #570
AKlowriderZ71's Avatar
11 Second Hall Moniter
Truck just keeps getting more awesome Corey, keep it up!
