BlackGMC build take 2 - Turbo Time
Old Jul 27, 2014 | 02:18 PM
  #771
BlackGMC's Avatar
Resident Retard
Ok so i fixed the damn noise. It was the fuel lines being attached to the firewall as seen in this pic. I removed them from the firewall and noise is gone.
Newest problem. I am having a belt alignment issue. Should not be a biggie to fix just more time.
Old Jul 27, 2014 | 02:50 PM
  #772
GMCtrk's Avatar
Do you just have holes in your firewall now?
Old Jul 27, 2014 | 03:48 PM
  #773
BlackGMC's Avatar
Resident Retard
Yep..
Old Jul 27, 2014 | 04:01 PM
  #774
BlackGMC's Avatar
Resident Retard
I think i fixed the belt alignment issue. Time will tell. I am gonna pick up an OEM belt at the stealership tomorrow. Thank goodness i have a buddy that works at the cadilac dealership and he gets me parts at his cost. Seems like i have spent a fortune up there lately.
Now i just gotta finish up the meth controller wiring and i am done.
Old Jul 28, 2014 | 09:55 AM
  #775
BlackGMC's Avatar
Resident Retard
So i drove the terd to work today. Everything ran great. Hopefully that last hurdle of the belt wanting to eject itself has been fixed. Surprisingly for as much crap as i changed the issues i encountered were minor.
Old Aug 3, 2014 | 09:33 PM
  #776
BlackGMC's Avatar
Resident Retard
Well i finally figured out the belt issue. Apparently i bent the damn alternator bracket. The ear that mounts the idler pulley was bent outwards causing the pulley to not line up and belt wanting to ride off the crank. I bent the bracket back straight and the test drive went well. The bracket is 3/8 Aluminum. So i found another company that makes a 3/4 thick bracket that is alot beefier so i ordered it.
Also i built an new efan harness. I got all the components from racetronix. All new relays and fuse holders. I got efan connectors from the stealership. I made redundant grounds in several places and used all 10 gauge wiring. When the fans kick on high with the AC on full blast. The idle is rock solid and no voltage dip. Hopefully i am good now.
I should have the truck all tuned up this week now that the METH kit is all wired in and working. I am ready for this project to be over with so i can enjoy the truck.
Old Aug 3, 2014 | 10:26 PM
  #777
00ChevyScott's Avatar
Wearin' da big hat
Let me know if you need help enjoying the truck
I've got a DSLR camera that I get some cool pictures with.
Old Aug 4, 2014 | 12:05 PM
  #778
TXsilverado's Avatar
start pushing some boost. i'm calling you out at the next LS1truck shootout just so i can see your truck on the track for once.
Old Aug 4, 2014 | 12:10 PM
  #779
BlackGMC's Avatar
Resident Retard
I would if i could but that damn bracket bent again and the ******* belt is slipping off again. I am gonna have to park it until the new bracket arrives which that company is taking its sweet time shipping it.
Old Aug 4, 2014 | 02:10 PM
  #780
oakley6575's Avatar
How much boost are you going to run?
