BlackGMC build take 2 - Turbo Time
#501
I have a gauge for that
High power setups means keep oil out of the intake at all costs. The can will catch most of it, but not all. Unless you use a check valve it will also boost the crankcase. Ironically, the time when the crankcase needs the most venting is under boost, just when the check valve closes.
#502
#503
I have a check valve between the intake and can to prevent boost in the crankcase. Both valve covers will be attached pre-turbo to help with venting. My catch can now is pretty much always dry. I am hoping with the addition of the ls6 valley cover the catch can will be even drier.
Also my truck is by no means a high hp setup. It probably only make 5-600hp. I only plan on 12-14psi.
#508
Man I coulda swore someone logged inch lbs and putting the vac to pre turbo wasn't enough vac at idle, cruise and wot to really help. Atomic is right, under boost the valve shuts and doesn't allow the crank case vent when it needs to most! The pcv to can to intake set ups like mine and many others on here only works when outta boost. Sob now I need to re think my whole setup and make the can use intake vac when outta boost and once in boost use pre turbo as the source.
