BlackGMC build take 2 - Turbo Time
Old Mar 25, 2014 | 07:03 AM
  #501
Atomic's Avatar
I have a gauge for that
High power setups means keep oil out of the intake at all costs. The can will catch most of it, but not all. Unless you use a check valve it will also boost the crankcase. Ironically, the time when the crankcase needs the most venting is under boost, just when the check valve closes.
Old Mar 25, 2014 | 07:39 AM
  #502
GMCtrk's Avatar
Or you use a catchcan which vents under boost, like mine. But you're right, the can definitely does not catch all the oil.
Old Mar 25, 2014 | 08:33 AM
  #503
BlackGMC's Avatar
Resident Retard
I have a check valve between the intake and can to prevent boost in the crankcase. Both valve covers will be attached pre-turbo to help with venting. My catch can now is pretty much always dry. I am hoping with the addition of the ls6 valley cover the catch can will be even drier.
Also my truck is by no means a high hp setup. It probably only make 5-600hp. I only plan on 12-14psi.
Old Mar 25, 2014 | 11:28 PM
  #504
Blown06's Avatar
8 Second Truck Club
500 or 1500 hp.....whatever
Don't connect the catch can to the intake. Just vent it to atmosphere.
Old Mar 25, 2014 | 11:38 PM
  #505
oakley6575's Avatar
Dumb question since I clearly don't understand the pcv system very well but why even run a catch can. I vented both valve covers to atmosphere to let it breathe when it needed to.
Old Mar 26, 2014 | 12:33 AM
  #506
stroker87's Avatar
I've done this on my 87 and the smell was horrible...... at times I smelled like a engine after a 30 mile or so drive I ran them to the intake too its n/a though
Old Mar 26, 2014 | 12:35 AM
  #507
oakley6575's Avatar
That is what kind of cologne I wear. Bitches think its delicious
Old Mar 26, 2014 | 11:04 AM
  #508
Choda's Avatar
Man I coulda swore someone logged inch lbs and putting the vac to pre turbo wasn't enough vac at idle, cruise and wot to really help. Atomic is right, under boost the valve shuts and doesn't allow the crank case vent when it needs to most! The pcv to can to intake set ups like mine and many others on here only works when outta boost. Sob now I need to re think my whole setup and make the can use intake vac when outta boost and once in boost use pre turbo as the source.
Old Mar 26, 2014 | 11:21 AM
  #509
Atomic's Avatar
Best idea, get a vacuum pump to always pull vac on the crankcase. Gives a little extra power too.
Old Mar 26, 2014 | 12:21 PM
  #510
TXsilverado's Avatar
would one of these vacuum pumps be enough to supply vacuum to both the PCV and a brake booster?
