BlackGMC build take 2 - Turbo Time
Old Jul 13, 2013 | 10:42 PM
  #251
Atomic's Avatar
I have a gauge for that
I have that same block, before they started charging 3x as much for it
It works well.
Old Jul 13, 2013 | 10:59 PM
  #252
BlackGMC's Avatar
Resident Retard
Good deal. I am kinda worried about first startup. I am thinking it may take awhile to fill up all the lines and cooler even if i prime the cooler and filter.
Old Jul 14, 2013 | 04:24 AM
  #253
Spoolin's Avatar
GFYS and STFU
Pull the fuse for the fuel pump and crank your motor for 15 seconds a couple times. Should prime the system. But don't overheat the starter.
Old Jul 14, 2013 | 09:08 AM
  #254
TXsilverado's Avatar
wow, I never would have thought that was a rattle can job.
Old Jul 14, 2013 | 11:08 AM
  #255
silver-mod-o's Avatar
Hunt&Fisherator
That, or just unplug the coil harnesses.... Either way will get the job done
Old Jul 14, 2013 | 03:16 PM
  #256
Tuckin15s's Avatar
This is a very nice build I just spent the last few hours reading it. I really like how simple the truck is, it really makes the whole thing look that much cleaner.
Old Jul 14, 2013 | 03:25 PM
  #257
Atomic's Avatar
Even easier, hold the gas pedal all the way down. More than 80% TPS during cranking turns off the injectors.
Old Jul 14, 2013 | 07:00 PM
  #258
BlackGMC's Avatar
Resident Retard
I got a little more work done today. I finally got my racetronix efan harness put on the truck. It is a really nice harness. It has all weathpack connections which is what i was wanting. My old harness was starting to corrode so it was time to replace it anyways. The harness had to be shortened a little bit which is no biggy. Here are the pics, i mounted it to the pcm cover.
Old Jul 14, 2013 | 08:42 PM
  #259
Hunt&Fisherator
Harness looks good!!
I forgot about the flood clear deal...
Old Jul 14, 2013 | 09:41 PM
  #260
Tuckin15s's Avatar
Harness looks good!
Are you guys having flooding up there? It has been storming all day down here in the killeen/fort Hood area.
