BlackGMC build take 2 - Turbo Time
Old Apr 22, 2013 | 02:39 PM
  #161
GMCtrk's Avatar
Originally Posted by idahoblkss
what is wrong with you guys ... lol
Well in my case I had a valve spring snap in half setting me back over a grand
Old Apr 22, 2013 | 06:21 PM
  #162
BlackGMC's Avatar
Resident Retard
any updates on this beast?
Also interested. Have you found traction yet?
Well i have been working on the tune and getting the meth consumption under control.
I bought a new set of leaf springs for my flip kit. I got new mounts for the assasin bars and FINALLY found some stock hangers.... I replaced all the bushings with new Poly bushings. I had to re-drill the middle leaf spring so i could slide back the middle leaf back 2 inches so the front mount of the assasin bars fit... I will post up some pics shortly...
he still hasnt gotten it above idle yet.....
whatever.... I did work on my idle the other day
I am a huge VAG.... I think i hit 80% tps the other day, then the tires spun at 80mph...
Old Apr 22, 2013 | 08:08 PM
  #163
GMCtrk's Avatar
If you lift a head that pushlok hose could pop off on your coolant crossover lines.
Old Apr 22, 2013 | 08:21 PM
  #164
Atomic's Avatar
I have a gauge for that
Thats like saying if you throw a rod through the block you might have an oil leak
Didnt think about redrilling the bottom leaf...I just cut off the end.
  #165
BlackGMC's Avatar
Resident Retard
I don't understand....
Old Apr 22, 2013 | 08:23 PM
  #166
BlackGMC's Avatar
Resident Retard
lol... Yeah that was mine plan tooo.. But 10 drill bits later, i have 2 new holes.... I did learn that going real real real slow with the drill worked 1000x better.
let me go snap some pics.
Old Apr 22, 2013 | 08:28 PM
  #167
BlackGMC's Avatar
Resident Retard
Pics
Old Apr 22, 2013 | 09:11 PM
  #168
Atomic's Avatar
Yea...I spent 20 minutes and 2 cutting discs just cutting off a few inches. When drilling hard metal use moderate pressure, very slow, and lots of oil. Cobalt bits are really nice for this.
Old Apr 24, 2013 | 12:15 AM
  #169
Spoolin's Avatar
GFYS and STFU
I haven't checked this in a while but glad to see you got it on and running Corey! Are you a lover of turbo boost now?
Old Apr 24, 2013 | 02:05 AM
  #170
tiffo60's Avatar
When I drilled the holes for my bars I had to use a carbide bit( got it from grainger) and spray oil on it just to keep it cool. I used a cut off wheel on a grinder to trim the springs.
