BlackGMC build take 2 - Turbo Time
Old Feb 9, 2013 | 05:00 PM
  #111
oakley6575's Avatar
Are you going to do some tuning today?
Old Feb 9, 2013 | 05:26 PM
  #112
NegraRCSB2X4auto's Avatar
I have a lot of wires that run through that same spot. I hate it!
  #113
BlackGMC's Avatar
Resident Retard
Hmmm no it is raining. Why do you ask?
Old Feb 9, 2013 | 05:30 PM
  #114
oakley6575's Avatar
Oh just wondering how much timing you will end up adding with the meth.
Old Feb 9, 2013 | 10:51 PM
  #115
BlackGMC's Avatar
Resident Retard
Oh probably 2-3*. I am wanting ti keep it pretty safe, just a fun daily driver.
Old Feb 9, 2013 | 11:15 PM
  #116
GMCtrk's Avatar
Are you running a COS 3/5 tune? If so, have you found a uniformity to the Boost VE table (meaning values for each row - kPa - are nearly identical)? The COS tutorial has you set up highly inflated values that increase with each row. But as I've been tuning I've been finding that the VE values for a given RPM at varying manifold pressures are quite similar.
Old Feb 9, 2013 | 11:22 PM
  #117
BlackGMC's Avatar
Resident Retard
I dont understand your question. I set up my boost ve table by copying the last row of the normal ve table and slightly increasing each column as i copied it over to be safe. Mine will be totally different because i am using a boost referenced FPR. My boost ve values actually go down as boost increases.
Old Feb 10, 2013 | 12:04 AM
  #118
Atomic's Avatar
I have a gauge for that
Yes, it depends on if your fuel pressure is boost referenced or not. VE should only increase if it is NOT boost referenced, and even then its really kind of getting around the problem. Remember VE is a measure of efficiency for the engine, so it should always be a value between 0 and 100%. It just so happens it acts as a catch all for fueling, so its easy to adjust fueling by the VE table. Weak fuel pumps will also require higher ve values in higher boost ranges.
Old Feb 10, 2013 | 12:14 AM
  #119
BlackGMC's Avatar
Resident Retard
Yep but our VE tables are not a true representation of volume efficiency because computer takes IAT and ECT into account. That is why some VE number come out iver 100%.
Old Feb 10, 2013 | 12:28 AM
  #120
Atomic's Avatar
Yes, thats why I made the comment it acts as a catch all for fueling. I should clarify by saying in theory engine VE should always be between 0 and 100%, and that may or not be the same as the VE table in the software depending on how the computer calculates fueling needs.
