BlackGMC build take 2 - Turbo Time
#116
Are you running a COS 3/5 tune? If so, have you found a uniformity to the Boost VE table (meaning values for each row - kPa - are nearly identical)? The COS tutorial has you set up highly inflated values that increase with each row. But as I've been tuning I've been finding that the VE values for a given RPM at varying manifold pressures are quite similar.
#117
Resident Retard
I dont understand your question. I set up my boost ve table by copying the last row of the normal ve table and slightly increasing each column as i copied it over to be safe. Mine will be totally different because i am using a boost referenced FPR. My boost ve values actually go down as boost increases.
#118
Yes, it depends on if your fuel pressure is boost referenced or not. VE should only increase if it is NOT boost referenced, and even then its really kind of getting around the problem. Remember VE is a measure of efficiency for the engine, so it should always be a value between 0 and 100%. It just so happens it acts as a catch all for fueling, so its easy to adjust fueling by the VE table. Weak fuel pumps will also require higher ve values in higher boost ranges.
#119
Resident Retard
#120
Yes, thats why I made the comment it acts as a catch all for fueling. I should clarify by saying in theory engine VE should always be between 0 and 100%, and that may or not be the same as the VE table in the software depending on how the computer calculates fueling needs.
