BlackGMC build take 2 - Turbo Time
Old 01-11-2013, 02:24 PM
Resident Retard
BlackGMC's Avatar
For the interim yep. I got tired of making fuel lines. The Aeromotive instructions said it was ok but ideally the fpr needs to be after the rails. My fuel pressure holds just fine and increases with boost like it should.
I have all the fittings, hose and fuel rails ready togo i just need some time to install them.
Here are the rails
BlackGMC is offline
Old 01-11-2013, 02:36 PM
I have a gauge for that
Atomic's Avatar
The problem with that is you will always be limited by the flow capacity of the regulator. How it is now, all the fuel has to pass through the reg, not just the extra unused fuel. At some point the regulator will be a restriction.
Atomic is offline
Old 01-11-2013, 02:39 PM
Resident Retard
BlackGMC's Avatar
Yeah i will put it after the rails in a little bit. It is doing fine now, i even have the 2nd fuel pump unplugged now and the Pressure is holding just fine. I agree with you eventually it will become a restriction when i up the boost
BlackGMC is offline
Old 01-11-2013, 02:40 PM
GMCtrk's Avatar
Originally Posted by BlackGMC
I believe i have a 50mm wastegate. Boost is very controllable. It never goes past 8psi and with various throttle positions i can run lower boost. .
Nice. That must be the same one I have then. Are you running the spring that came in the wastegate? According to JGS's website, they come with the lightest spring installed.
GMCtrk is offline
Old 01-11-2013, 02:49 PM
Resident Retard
BlackGMC's Avatar
Yep i am running the small spring
BlackGMC is offline
Old 01-11-2013, 04:37 PM
Resident Retard
BlackGMC's Avatar
New snow performance meth controller came in today. The devils own controller is next to it.
BlackGMC is offline
Old 01-11-2013, 05:09 PM
11 Second Truck Club
fastrt's Avatar
Wow! nice job man I can't wait to see it...or ride in it
fastrt is offline
Old 01-11-2013, 05:48 PM
Lookin' good Corey ! Should be lots of fun
NvrDun is offline
Old 01-11-2013, 05:59 PM
Resident Retard
BlackGMC's Avatar
Thanks man.
I got the Snow Performance controller mounted and the new washer tank modded. I am planning on putting it on the passenger side next to the air cleaner. I mocked it up and it fits great.
Bulkhead installed and low level switch installed
BlackGMC is offline
Old 01-11-2013, 06:12 PM
Resident Retard
BlackGMC's Avatar
Check Valves all installed. I installed on the the fresh air side of the PCV inlet because i did not want it sucking any oil/vapor from the motor when i really turn the turbo up. Not sure if pre-turbo will ever get much suction but i have seen a few guys colaspe air filters on turbo setups due to sucking in air. Anyways looks kinda cool plus i have like a billion AN fittings.
Please excuse the state of my wiring. It is on the list to clean up.
Btw the checks valves are sold by Boomba Racing
Check Valve inbetween the catch can and intake
And finally one on the brake booster. I had this one laying around left over from something
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
