BlackGMC build take 2 - Turbo Time
Old Jan 11, 2013 | 01:03 PM
BlackGMC's Avatar
Resident Retard
Default BlackGMC build take 2 - Turbo Time
Well i have been gathering parts and planning for the last year or so do finally go Forced Induction. I went with KBRacing on the kit, great guy to work with and he helps you along the way. KB is a great asset to the boards!
so here is the run down on my truck.
2004
LQ9
Stock 317 heads with Brian Tooley .660 dual springs
220/224 .581/.581 115+5
NNBS truck intake with 87mm TB
Yank Pro Truck Multidisk 3200 TC (I love this thing!!!)
2001 4L80e i built myself
Fully rollerized
parts of the HD-2 shift kit
Dual Feed mod
Sonnax self regulating boost valve, Sonnax TCC regulator
And a few other goodies
KBRacing BW S475 T4 kit
4in down pipe
3.5 Magnaflow Cat-Back spliting into 2.5 pipes dumping at the roll pan.
Standard KB intercooler, BOV and wastegate
Dual Walbro 255 pumps
-8 PTFE feed line
-6 PTFE return line
Aeromotive A1000 FPR
FIC 1000cc injectors
Dual RaceTronix Hotwire kits (one standard GM one and one Universal)
Devils Own Meth/Snow Performance METH kit
now on with the pics
Fuel pump and wiring
Cooling system upgrades
Hot Pipes, i forgot to take a pic when they were painted
4inch to 3.5inch pipe extension
-10 drain line
Intercooler mounted
Charge pipes painted
Vacuum manifold installed
Finished product
Old Jan 11, 2013 | 01:13 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
CLEAN install Corey, it looks great man!
Old Jan 11, 2013 | 01:16 PM
chevrolet all the way's Avatar
great work corey! it looks awesome! i like to see people take their time on a build like that. I also like that charge pipe color!
Old Jan 11, 2013 | 01:26 PM
slowec's Avatar
Super nice install !
Care to share those coolant mod specs? Nice work man.
Old Jan 11, 2013 | 01:27 PM
BlackGMC's Avatar
Resident Retard
Thanks man, it is a 10 footer right now, i have a lot of clean up todo under the hood, mainly some wiring...
BTW, i am loving the converter you speced for me! it is great in boost it does not push past it at all, and it loads the turbo very well!
Thanks yeah, the color is pretty cool but it sucks because you don't see any of it... oh well i know it is painted
Old Jan 11, 2013 | 01:30 PM
BlackGMC's Avatar
Resident Retard
sure here you go
mixture of -4 and -6 pushloc, i got the steam vent adapters from ebay
https://www.performancetrucks.net/fo...-hoses-511439/
the coolant tank is from a 2010 chevy aveo.
https://www.performancetrucks.net/fo...t-tank-510610/
Old Jan 11, 2013 | 01:33 PM
03sierraslt's Avatar
Looking good man.
Old Jan 11, 2013 | 02:03 PM
GMCtrk's Avatar
I like how you did the install. On mine though I mounted the intercooler directly under the crossbar. I had to get longer bolts from HD though.
And you're Able to control it at eight PSI with the 40 mm wastegate?
Old Jan 11, 2013 | 02:07 PM
BlackGMC's Avatar
Resident Retard
I believe i have a 50mm wastegate. Boost is very controllable. It never goes past 8psi and with various throttle positions i can run lower boost. .
Old Jan 11, 2013 | 02:18 PM
Atomic's Avatar
I have a gauge for that
Do you have the fuel feed going to the regulator first then to the rails?
