BlackGMC build, suspension, fuel system, exhaust etc...
Old Jul 20, 2012 | 10:01 PM
  #41
BlackGMC's Avatar
Resident Retard
I am curious too. I am gonna try to run the angled back and down. I will know more tomorrow once the welder is cooking.
Old Jul 21, 2012 | 12:51 AM
  #42
oakley6575's Avatar
Yea post pics once you get it welded together. I'm interested to see what it looks like when all said and done
Old Jul 21, 2012 | 10:20 AM
  #43
TXsilverado's Avatar
lookin good.
Old Jul 21, 2012 | 12:10 PM
  #44
black04's Avatar
Looks awesome. i like the factory fill location. I may have to try that next time i take the box off.
Old Jul 22, 2012 | 12:16 AM
  #45
BlackGMC's Avatar
Resident Retard
Well i am finally done.... It took longer because i had to tie up a lot of looses ends (wires, vent lines, fuel lines, etc)... Basically i did everything i could so the i would not have to take the bed off again until the 4-link starts going together and that is a ways off... Also i pressure tested the cell, and i had a little leak at the fuel sending unit, so I had to tighten it up some, also one of the vent line AN fittings was a little loose (my buddy put that one on...)
The exhaust sounds freaking awesome.. it is whisper quiet at 60mph, it gets throaty as **** when your going WOT, and flat out screams at 6500rpm!!! It talks a little bit at idle, but if i had a bigger cam you would really be able to hear it...
I have the tips pointing down at an angle, basically pointing right at the tire, which thinking back that was a bad idea so i gotta fix it...
OH part of the 1 hour long ordeal after everything was back together and getting ready for the first drive... Apparently i had a screw going through the rear wiring harness. It was shorting out the wire to the fuel pump, which was popping the PCM B fuse... Once we found that everything was all good.
OH and taking the factory fuel lines and EVAP lines out in 1 piece was SUCH A PIA!!!!!
Below are the pics!
Old Jul 22, 2012 | 12:17 AM
  #46
BlackGMC's Avatar
Resident Retard
BTW, removing all those crossmembers, now i have SO MUCH ROOM under the truck!!!
Old Jul 22, 2012 | 01:58 AM
  #47
oakley6575's Avatar
Looks good. Can't wait to hear it!
Old Jul 22, 2012 | 07:55 AM
  #48
silver-mod-o's Avatar
Hunt&Fisherator
Need to go get some new times with these changes...
Old Jul 22, 2012 | 08:40 AM
  #49
Atomic's Avatar
I have a gauge for that
Do you have any better pics of that upper shock crossmember? Specifically about how you attached it to the frame?
Old Jul 22, 2012 | 09:06 AM
  #50
ak2007r6's Avatar
Looks good. Any sounds clips?
