Back in the game. RCSB 1500 D-max swap coming...
Old May 26, 2014 | 08:01 PM
  #581
thunder550's Avatar
High on diesel fumes
Originally Posted by s/c'd cav
and what no hey wanna go for a ride
You were doing something important like working I think...
What the hell were you listening to?
Opera
Old May 26, 2014 | 08:03 PM
  #582
s/c'd cav's Avatar
working inst important
Old Jun 9, 2014 | 10:35 PM
  #583
thunder550's Avatar
Got a 12 second pass in Friday night. Just once, and just barely...but it counts 12.97@104.7
Still on stock motor, stock turbo, stock airbox, stock trans. Race weight 5310 lbs, DA 4461 ft. Got 9 passes in total...the other 8 were 13.0x.
Left lane in the photo below.
Here's a video of one of the 13.0x passes too.
1500 dmax wild horse 6/6/14 - YouTube
Old Jun 9, 2014 | 10:38 PM
  #584
s/c'd cav's Avatar
very nice , sucks i was home sick
make sure and post up on azgmp
Old Jun 9, 2014 | 10:42 PM
  #585
1FastBrick's Avatar
Custm2500's Rude Friend
You should put a big *** cattle bumper on that truck and turn up the boost!!!
Old Jun 14, 2014 | 06:22 PM
  #586
thunder550's Avatar
Installed a set of OEM half ton electric fans. Had to do a lot of trimming on the fan shroud to get the tabs to sit in the radiator slots. Made some brackets to go from the shroud to the radiator support, and cut up my clutch fan shroud to cover the gap at the top. Relocated my TCM to a small gap between the radiator, battery, and ECM. It's not secured in place but there's no room for it to move around so I think it's ok?
Rigged up a harness with a manual switch inside the cab for power on/off until my DC Control fan controller arrives. It's working great
Lower radiator hoses touch the fan shroud, but there's little to no pressure pushing them up against the shroud so I think this is ok.
TCM location
Finished product
Old Jun 14, 2014 | 09:49 PM
  #587
oakley6575's Avatar
Looks good man. That engine compartment could use a power washer. Your sig pic is awesome btw
Old Jun 15, 2014 | 01:46 AM
  #588
s/c'd cav's Avatar
so what happened to making a couple metal tabs to sit in the lower radiator catches ?
you didnt mention the alt swap , lol
Old Jun 15, 2014 | 10:39 AM
  #589
thunder550's Avatar
Wasn't necessary once I got the fans to sit in the slots. Making brackets for the upper mounts was easier than the lower I think, or at least easier to test fit.
Oh yeah, I also swapped from the stock 105 to a 145 amp alternator. Got the fans and alt both from a local junk yard for $200.
Old Jun 15, 2014 | 03:14 PM
  #590
s/c'd cav's Avatar
but the lift body blocks woulda looked cooler
