B&M ratchet shifter install in a GMT800
Old Sep 22, 2009 | 09:37 PM
  #21
GMCtrk's Avatar
The question is whether or not it is just like shifting the stock lever or not. I mean you change change the gears on it but the computer won't shift until it's ready.
Old Sep 22, 2009 | 09:41 PM
  #22
qatar-streets's Avatar
yes bro as charcoal said the tow haul button ?? "sorry for the miss writing the question"
cuz Im not a native speaker sorry again
Old Sep 22, 2009 | 10:20 PM
  #23
truckmann's Avatar
It may be hard to get if you never had a ratchet shifter, but the ability to change gears, specifically to downshift when ever you want is fun, and with a good ratchet shifter there is no worry about missing a gear or downshifting too far.
Old Sep 23, 2009 | 05:07 AM
  #24
Spoolin's Avatar
GFYS and STFU
It's just a differnt way to select gears. It works the same as your colum shifter except when you manually select gears such as 1-2-3 you can slam or "slap" to the next gear rather than gently moving the column shifter into the next gear without accidentally skipping a gear. If you put it in Drive mode it will drive same as normal, you put it in 2nd and it will drive same as if you had it in 2nd with a column shifter. It doesn't affect the way the tranny shifts, it affects the way you shift.
Comprende?
Old Sep 23, 2009 | 09:16 AM
  #25
04SilveradoMykk's Avatar
I don't typically use my tow/haul button, if ever at all.
However I'm thinking of re-mounting it and making it refer to the performance tables set up for manual shifting. Pretty much making every gear shift all the way to 4th at a very low MPH, and disabling TCC.... this way the trans will stay in whatever gear I have the ratchet shifter in and wont apply TCC
Old Sep 23, 2009 | 09:17 AM
  #26
charcoal03silvy's Avatar
I think Transgo makes a shift kit like that.
Old Sep 23, 2009 | 09:26 AM
  #27
But can it go back to normal automatic shifting at the touch of a button?
Old Sep 23, 2009 | 09:28 AM
  #28
This is true haha! Sounds cool, go for it!
Old Sep 23, 2009 | 11:00 AM
  #29
Spoolin's Avatar
GFYS and STFU
Hey what part number on B&M's websight is ur shifter? I was looking for it but couldn't find it. It'll work on a 80e as well I assume?
Old Sep 23, 2009 | 01:44 PM
  #30
blkssncpt's Avatar
thats definately cool, i wanted to do this on my SSS but i'd have to cut the air conditioning vents under my center console...
Julien look up Dozer over on sss.com he also had a really good write up on how to do this shifter, looks awesome nonetheless. still might do this in the future...
-Rob
