Aluminum LS2 Build
Old Sep 5, 2011 | 02:26 PM
  #21
Here are some updated photos of the work done so far. Would have had the motor done if there weren't some loose ends.
Old Sep 29, 2011 | 06:44 AM
  #22
beastmode's Avatar
Import Moderator
Little bit of a thread dig but how is this going Chase?
Old Sep 29, 2011 | 08:19 AM
  #23
Well, to make it a short story it is in and running finally. Ran into about every snafu that you can think of. Truck sounds really healthy and has good power although I can't check it out too much because my e-fans are kicking on, so there are a few tweaks in the tune we still have get ironed out and then a lil bit of break in before . I need to get some pics up of the setup, the 8 rib is freaking sweet!! Although I haven't been able to test it out yet. Let me know if you want to hear the long story of all the problems. Or maybe Kasey will chime in since he had all the fun with me..
Old Nov 15, 2011 | 12:29 AM
  #24
364HC's Avatar
Banned
any - updates, on this build?
Old Nov 15, 2011 | 12:43 AM
  #25
AKlowriderZ71's Avatar
11 Second Hall Moniter
Not sure how I missed this.....
I/W 8 rib pulleys, head studs, etc. has me guessing that the P1 is just a starting point for you. Care to leak out your future plans?
Old Nov 15, 2011 | 07:37 AM
  #26
running strong....he put a race b/o valve on it that sounds ridiculous. ill put an idle vid of it up. Im sure Chase has some vids to put up also.
Old Nov 15, 2011 | 03:57 PM
  #27
Yea there are definitely future plans in the works.. I'm looking to do a Lonnies Performance duel intake setup on a hobbs switch at 3 psi. The stock pump does pretty good until about 6400 rpms then it starts to drop off. The P1 is a starting point, looking to go to a D1 with a 3.55 pulley and let'er eat. If that doesn't do the job we will see bout a bigger blower. But traction and wheel hop will be a concern for sure... Want to know anything else bout the setup just holla at me...
Old Nov 15, 2011 | 04:13 PM
  #28
USMCvet0311
Aug 14, 2015 10:28 PM
BennyB
Aug 1, 2015 08:48 AM
Ammadien
Jul 22, 2015 08:50 PM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
