Aluminum LS2 Build
After many months of planning out and parts collecting I have finally started to put together a motor with the help of Kasey (06tx4.8).
LS2 aluminum block bored .10 over 317 heads Lunati double springs (660 lift) Mahle forged pistons LS2 timing chain LS7 Lifters ARP head studs stock bottom end Katech rod bolts 60 lb. injectors 8 rib setup from leftcoast 32 P-1SC (10-11 lbs.) custom cam (222/230 .602”/.609” 117LSA +2 advance) Melling High volume oil pump And of course Wheatley to top it off with a tune! I know I have probably missed something but if you want to know just ask, now on to some of the eye candy. http://i452.photobucket.com/albums/q...C6B07-orig.jpg http://i452.photobucket.com/albums/q...6A6F7-orig.jpg And the hotrod its going in (beastmode's old rig) http://i452.photobucket.com/albums/q...E86CA-orig.jpg |
I love that color truck!!!
gonna be a sweet motor!!
i dont mind u tellin em its me!!!!.....yes, when we are done with his truck, its gonna run good!!!!!! we are about ready to do the swap.
Originally Posted by 5.0 Eater
(Post 4720322)
After many months of planning out and parts collecting I have finally started to put together a motor with the help of a buddy who shall remain nameless unless he wants his name out there :secret:.
LS2 aluminum block bored .10 over 317 heads Lunati double springs (660 lift) Mahle forged pistons LS2 timing chain LS7 Lifters ARP head studs stock bottom end Katech rod bolts 60 lb. injectors 8 rib setup from leftcoast 32 P-1SC (10-11 lbs.) custom cam (numbers to come later) Melling High volume oil pump And of course Wheatley to top it off with a tune! I know I have probably missed something but if you want to know just ask, now on to some of the eye candy. http://i452.photobucket.com/albums/q...C6B07-orig.jpg http://i452.photobucket.com/albums/q...6A6F7-orig.jpg And the hotrod its going in (beastmode's old rig) http://i452.photobucket.com/albums/q...E86CA-orig.jpg |
Originally Posted by 06tx4.8
(Post 4720372)
hey.....that looks like my garage!:cool:....oh yeah, it is:secret2:
Shh....Can't let all the secrets out...:secret: Thanks for the compliaments fellas. |
Damn that's a good looking build!
Originally Posted by Midnight
(Post 4747867)
(Post 4748187)
Yea I'm unpatiently waiting for the heat in Houston to reside some so me and Kasey aren't just sweating the entire time. :cry:
Any vehicle work these days I start at 6am and shut it down by noon and thats it. |
(Post 4748205)
Tell Kasey to quit being a puss and get it done :D
Any vehicle work these days I start at 6am and shut it down by noon and thats it. Man, its still brutal out there even early in the morning. I mowed the yard this morning at about 8:30 and lost 4 lbs of water in 2 hours. And it sux that the truck may be down for awhile to do the swap. |
