'89 Chevy C1500 5.3 turbo build
Old 03-18-2013, 02:31 PM
  #151
BigBlock90's Avatar
Originally Posted by LS1FREEK
Not sure on that but probably so, I actually hooked the SGI-5 box to the factory vss wires from the 89 body.
This way I could use the stock 89 cruise control if I would want to.
oh i gotcha......i was thinking backwards on that. ive had turbo 350 and turbo 400's in my truck for years and havent had a speedo working since i tore up my stock trans years ago. i cant even remember if it was a single wire or a 2 wire plug that hooked to the factory trans for the speed signal. i still have the factory harness tied up under the truck so i guess i need to dig through it and see what i got... how many wires did you have to hook up with the SGI-5 box?
sorry for all the questions, but i thank you very much for your help
Jamie
Old 03-19-2013, 08:22 AM
  #152
13 Second Truck Club
LS1FREEK's Avatar
Videos!!
https://www.performancetrucks.net/fo...4/#post5081299
Old 07-12-2013, 12:23 PM
  #153
LS1FREEK's Avatar
Been a while! Few updates! Sold the 03 LQ4 and bought me a newer stronger 06 LQ4! Also got me some ARP head bolts, a Stock48 spec'd Isky cam (215/215) and gonna build a bigger down pipe, prob a 3.5"
Gonna try to get the new engine installed this weekend!
Old 07-12-2013, 10:40 PM
  #154
UnVmy5.3's Avatar
Swell...
Old 07-15-2013, 02:02 AM
  #155
oakley6575's Avatar
Questons. What made you decide on a smaller cam? Why did you swap turbos from the Turbonetics to the CX?
Old 07-15-2013, 06:59 AM
  #156
LS1FREEK's Avatar
Cam is not necessarily smaller, the duration may be slightly smaller but the lobes are much more aggressive, .41" more lift, 2* tighter LSA and 1* more advance. It should spool the turbo quicker and get me a better 60ft off the foot brake. All about efficiency, making all your parts work together!
The CX turbo has bigger wheels (TC76: 74.7x68mm, CX:76.6x77.4mm) MUCH bigger housings and A/R (1.15 vs .96)to flow alot more air), and ball bearing! Despite everything being bigger, the turbo still spools just as quick or quicker, I absolutely love it! And its WAYYY louder. To say the least, I wanted more efficiency, the CX turbo is making a noticeable amount more power in the higher boost/RPM areas, it more efficient!
Old 08-26-2015, 02:27 PM
  #157
Registered User
Gilbert Buentello's Avatar
Default exhaust tubing
Here's what the truck/progress looks like lol
Hey bro were did u get all you exhaust tubing eBay or local shop
Old 09-24-2015, 07:24 AM
  #158
LS1FREEK's Avatar
Got the exhaust tubing from Tube Bending & Fabrication - Columbia River Mandrel Bending
Old 09-24-2015, 07:26 AM
  #159
LS1FREEK's Avatar
Never did post a picture of the finished build with the GT45 turbo.
Old 09-28-2015, 09:52 AM
  #160
89c1500's Avatar
Love this build!! I had a LQ9 Carb'd in my 89 1500 and loved it. Now that its gone i think its time to do exactly what you did!!
Quick Reply: '89 Chevy C1500 5.3 turbo build
