6.0 Turbo build
Old Oct 25, 2015 | 09:16 PM
  #241
GRRR65GTO's Avatar
Which style boost works better? I know vortec got the first ones but im just wondering
Old Oct 25, 2015 | 09:50 PM
  #242
Atomic's Avatar
I have a gauge for that
I keep telling guys...if anything is touching the pipes on a turbo setup, it will melt no matter how much wrap you put on it. I ended up having to make custom wires on mine of all different lengths so they were not touching anything.
Old Oct 26, 2015 | 08:32 AM
  #243
GRRR65GTO's Avatar
Yeah thats why Im getting the angled boots, the stock straight wires touch but angled ones shouldnt
Old Oct 26, 2015 | 09:16 AM
  #244
GRRR65GTO's Avatar
Ended up getting the first set, the boots look shorter than that the second set, hopefully they wont touch. This must have happened because when the manifold was machined it was not perfectly level and the angle its on now makes it touch the stock wires....
Old Oct 26, 2015 | 09:34 AM
  #245
Atomic's Avatar
My log manifold warped like crazy over time, like a good 1/2" or so. The cast manifolds do much better. You might want to inspect your manifold around the welds as well.
Old Oct 26, 2015 | 10:17 AM
  #246
GRRR65GTO's Avatar
I know trick's manifolds look nice but then I have to redo my whole hotside or buy a trick hotside. Worst thing that happens is the flange gets cut off and a 1/2" thick ones gets welded on. I dont see why that wouldnt work
Old Oct 26, 2015 | 10:19 AM
  #247
Atomic's Avatar
By cast I also mean the stock truck ones, but yes that means redoing your pipes either way. Im not saying you have to, im just saying if you start running into warping and cracking issues (at the welds) you might have gotten your life use out of what you have. A thicker flange may not help you. Hot metal wants to grow, and stainless grows a lot more than mild.
Old Oct 28, 2015 | 10:56 AM
  #248
GRRR65GTO's Avatar
So I made a stupid mistake and ordered car wires. But the wires after one trip to vermont arent toasted so Im just gonna say **** it and go on friday on the last street night and run it. Now im tore between ordering the right set of taylor wires that I could possibly cook or getting the accel ceramic booted ones that stand up to 2000 degrees. Im kind of leaning toward those and never worrying about that again...
Old Oct 28, 2015 | 11:38 PM
  #249
Blown06's Avatar
8 Second Truck Club
I'd call Firecore and be done with it.
Old Oct 29, 2015 | 12:27 AM
  #250
Vortec350ss's Avatar
How long are the car wires? 9"? They will fit my set up better. I have the truck 12's.
