6.0 Stick Shift Tahoe (NV4500)
Old May 24, 2021 | 03:07 PM
  #351
wretched73's Avatar
Wow, they really look great. Just for looks its worth every penny
Old May 24, 2021 | 03:13 PM
  #352
dantheman1540's Avatar
Thank you! That was the main reason to do it. Oh, and gotta have that "new new" while it's hot.
Old May 24, 2021 | 08:36 PM
  #353
adriver's Avatar
The NNBS rears are a 13.6" rotor with a single piston caliper. The NBS SUV rears are a 13" rotor with a dual piston caliper.
Old May 25, 2021 | 06:42 AM
  #354
Good to know thank you! Got any ideas on a 4 piston rear setup or something that looks better for less than $2k?
Old May 25, 2021 | 02:57 PM
  #355
adriver's Avatar
I really don't think there is one for the rears. The NNBS/K2XX rears have a 13.6 rotor with a single piston caliper (if not drums). The NBS SUVs have the 13" rotor with a 2 piston caliper. Baer makes a 2 piston floating caliper with a 14" rotor that uses dodge something pads for about $1500, (which doesn't seem worth it). I think for the rears if you want big you have to go wilwood or brembo for a few grand. I wouldn't put those on without the biggest of brake kits in the front, or you know you'll be fishtailing.
The 2021s are using a rotor thats the same 13.6", but has about an inch bigger hat size. If you wanted to do the legwork, they MIGHT have a better caliper, but then you will have to see if the newer rotors will work. The newer rotors will sit that "about an inch" deeper in. I really think your factory brakes are the best option.
Old May 25, 2021 | 03:01 PM
  #356
shakenfake's Avatar
Shlumpt
5 Year Member
I say get the NNBS rotors and calipers, iirc someone did test and say they had a bit better heat dissipation and brake stoppage
Old May 25, 2021 | 03:27 PM
  #357
That pretty much the conclusion I came to.
Ehh if they don't look any cooler then its not worth it IMO this truck stops fine I just like the blingidy blingidy ****.
Also, I confirmed the previous front brakes were 12" rotors so that's OEM style NBS brakes but probably a powertop kit since the rotors were drilled and slotted.
Old May 25, 2021 | 03:33 PM
  #358
shakenfake's Avatar
Shlumpt
5 Year Member
It is blingidy blingidy you get to tell everyone you retro fitted like a wizard
Old May 25, 2021 | 03:44 PM
  #359
Now I need cool new blingidy bling wheels that show off the blingidy bling calipers. been eyeing these Cosmis wheel since 03sierra and somebody else on here got them but, I'm unsure how they will look on an SUV.
Old May 26, 2021 | 11:26 AM
  #360
Or be a baller and step up to some twenty twos, just don't want to lose much sidewall.
