5.3 setup :)
Old Aug 17, 2011 | 03:12 PM
  #21
watkins911's Avatar
Well Im a newb on spray you Always hear horror stories about it messing up stuff. But would a 150 shot or so hurt?
Old Aug 17, 2011 | 04:50 PM
  #22
AndysC3's Avatar
not sure if I missed it but what year is your truck? since it only has 38K I'm assuming 2010+. is it flex fuel? who did the tune? A 150 shot would probably be the max on a stock bottom end engine. and you WILL need a built trans to handle the abuse. you can also get away with using a 26-2800 stall with anything under 220. I'm about to through in a 224/230 on a 114LSA and just ordered a Circle-d 4C (3600-3700) stall. It all depends on what your ultimate goals are for your truck. is it your DD or just a weekend warrior? do you have to tow with it. all these things factor in to your build.
hope this helps.
Old Aug 17, 2011 | 05:35 PM
  #23
bmd_CL's Avatar
im pretty sure you can spray more than a 150 shot on a stock bottom end, you could actually spray a 125 shot on stock timing. besides, the bottom ends of these motors are stout, one can normally handle upwards of 10lbs of boost easy and a 200 shot is about the equivalent to 8 psi. buy a nitrous kit and spray a 100 shot all day long.
Old Aug 17, 2011 | 06:47 PM
  #24
watkins911's Avatar
It's a 2001 model weekend warrior and maybe 100 miles a week if that. And no towing I would build the trans. I just want to know a good cam. Lifters springs and pishrod setup. Since I will have it torn down might as well do it good and do it all since im in there and 100 shot sounds sweet
Old Aug 17, 2011 | 08:38 PM
  #25
Chevy_King1500's Avatar
are you changing heads?? alls you have to take off is valve covers and front cover
Old Aug 17, 2011 | 09:44 PM
  #26
watkins911's Avatar
Take those off for what!? Not changing heads yet want to do a cam forst
Old Aug 17, 2011 | 09:53 PM
  #27
cam...you can't change lifters with out pulling the heads. and you might as well upgrade if you go that route
Old Aug 18, 2011 | 04:40 PM
  #28
watkins911's Avatar
Well Texas speed has a 224 cam. With hardened pushrods and springs. I'll go ahead and get ls7 Lifters. Would this be a good setup!?
Old Aug 18, 2011 | 04:46 PM
  #29
AndysC3's Avatar
the ls7 lifters have a slightly higher bucket than stock. you may need 7.350 pushrods.
Old Aug 18, 2011 | 07:45 PM
  #30
watkins911's Avatar
Well I guess that's what would come with the kit
