4.8 Samurai build
Old Sep 15, 2011 | 06:48 AM
  #41
custm2500's Avatar
Ph.D. in HUBRIS
Looking good. I want to see thing thing pull a wheelie! If you don't stop putting heavy steel in the chassis it will never happen!!
Old Sep 15, 2011 | 07:34 AM
  #42
nonnieselman's Avatar
Haha. Im just ready to go riding around in it. The suspension is alot softer than i was expecting so its gotta ride better than it did with them worn out springs it had.
That square tubing is thin, that cage might weigh 3 pounds. The body is flimsy where i cut the tunnel out at so this was a easy way to get some strength in it. And put the diamond plate on it for a center console.
I gotta figure out a transfer case shifter and a throttle cable.
Old Sep 15, 2011 | 03:12 PM
  #43
custm2500's Avatar
Ph.D. in HUBRIS
no need for a throttle cable. Off or full throttle are the only two you need.
Old Sep 16, 2011 | 07:44 AM
  #44
Not exactly ideal for night time riding on the farm lookin for hogs.
I found lokar has a cut to fit throttle i might try
Old Sep 18, 2011 | 09:42 AM
  #45
Finished up my dash last night for the most part.
  #46
Old Sep 18, 2011 | 09:44 AM
  #47
Tryin to finish the wiring harness.
Old Sep 19, 2011 | 02:54 PM
  #48
Guess you can call it a 5.3 sami now
Old Sep 19, 2011 | 09:35 PM
  #49
lglowe's Avatar
Gonna be sick buddy !
Old Sep 19, 2011 | 10:38 PM
  #50
Got this panel installed tonight. What ever you wanna call it. Bumper gap filler?
Started on wiring and got a few things done. Got a long way to go!
Started on the transfer case shifter. Boy is that gonna be crazy. Dunno if ill even take a picture of that when im done. Might confuse my phone haha.
Soon as i finish soldering the wires to the cam sensor im puttin the harness on and my fuse blocks will be in tom along with my brakes.
All in the while im sanding and painting one panel at a time. Krylon ultra flat black. It looks good so far. Same stuff i did the dash and everything else in.
