2012 RCSB 416ci TVS2300
Old Nov 25, 2012 | 04:08 PM
  #131
Atomic's Avatar
I have a gauge for that
In that case a 370 with a 91!
Old Nov 25, 2012 | 06:46 PM
  #132
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by supercharged680
update! so i don't think this engine is ever gonna work out cause the guy who built it is a complete idiot.. the pinning was done incorrectly it ruined my arp bolt , balancer hub and crank thread.. took everything out to replace my crank and guess what.. my crank bearings and rod bearings were thrashed.. i guess the engine builder never lubricated them or something so the engine is currently sitting at my friends shop.. im about the pull the trigger on a 10.0:1 416ci short block from the US
Most likely the parts were not cleaned, measured, and assembled properly.
This biggest thing with aftermarket cranks and especially stroker cranks is to check the bearing journals for size in several spots. Sometimes the journals are not finished properly. If you use the wrong bearing or if the journal is not perfectly round you will have issues with bearing life. Crank manufactures don't want you to know that there cranks are made and finished over seas. Some companies will finish them here for quality control but most don't. The only cranks actually manufactured here are the Billet one's. There usually custom made to order and not massed produced. That's why they cost thousands of dollars.
As most have said go with an Iron block and build a 370 or a 402.
Old Nov 26, 2012 | 02:21 AM
  #133
chvz99's Avatar
nice build you had going,
have you considered the gm lsx376, upgrade the rod bolts /head studs.
then put your tvs on it / and let us know how much boost it can take. lol
ihave this motor on my truck and im planning for a tvs 2300
Old Nov 26, 2012 | 10:41 AM
  #134
supercharged680's Avatar
still having thoughts on who should build my engine since i had a bad first experience lol.. im going to the shop today to pickup my disassembled engine ill take a few pictures.. i have a few parts up for sale.. to bad i can't sell it to u guys cause your on the other side of the world lol
Old Nov 26, 2012 | 03:23 PM
  #135
500-600 miles only
so called balancing lol
bearing to rod journal and bearing to rod clearances were stock.. with aftermarket bearings.. he did not machine anything at all just the block.. he screwed that too.. 6 thou piston to wall clearance.. lets hope this doesn't happen again
Old Nov 26, 2012 | 04:57 PM
  #136
SLCviaAK's Avatar
Not sure which companies you are considering for your new motor, but the ones that I consistently hear good things about are
AES
TSP
ERL
Old Nov 26, 2012 | 04:58 PM
  #137
SLCviaAK's Avatar
Also Kurt Urban performance.
Old Nov 26, 2012 | 05:03 PM
  #138
03sierraslt's Avatar
Wow, those are some interesting pictures.
Old Nov 26, 2012 | 05:33 PM
  #139
Spoolin's Avatar
GFYS and STFU
If your a big baller than I would suggest Dutweiller, he also ships lots of motors out to the Middle East and a good rep.
Also Jarrett (stock48) can build you a mean *** engine. Ask me how I know!
Old Nov 26, 2012 | 07:41 PM
  #140
SLCviaAK's Avatar
Totally forgot about our very own stock48!
